Hi Guys! Need a second opinion. Pulling my engine for the first time (77 280z). Front chain is mounted to the sligner, but the 6th exhaust cylinder bolt is sheared off so I can't use the back one.  I saw that a few members have used ratchet straps so I got the 1000lb working rating strap and wrapped it around the bellhousing.  Could you guys give this a second look before I pull the engine tomorrow? Where should the strap be connected to the leveler? Right now I have it through th
