December 22, 20213 yr comment_633437 . I was having an impossible time sealing SS kit from Classic tube . First off you need to check for burrs on the flares . The SS lines will destroy OEM fitting flares if they don’t match up well. I finally found these and they seem to have fixed the issue https://www.amazon.com/Parker-Degree-Fitting-Flare-Gasket/dp/B077NHZ98C Link to comment https://www.classiczcars.com/forums/topic/66171-seating-brake-line-fittings/?&page=2#findComment-633437 Share on other sites More sharing options...
December 22, 20213 yr comment_633440 Thats why I asked earlier if they were stainless . Stainless can be very difficult to seal, especially if the flares aren't perfect . Link to comment https://www.classiczcars.com/forums/topic/66171-seating-brake-line-fittings/?&page=2#findComment-633440 Share on other sites More sharing options...
December 22, 20213 yr comment_633446 On 12/21/2021 at 1:45 AM, Zed Head said: take a close look at the actual fluid sealing surfaces. One tip i have.. Take your phone and go into the camera's "adjustments" put focus from autofucus on macro.. then take a picture from the connections insides and you can see MUCH more of the sealing surfaces.. Many times i have seen things this way on a picture that was not visable in good lighting with the eyes.. When you make a picture sometimes you have to "click or tip" with your finger on the screen just to let the camera focus just before you make the picture! You be amazed what you see this way!! Don't forget to put it back on autofocus later on.. and put that all revealing pic on here!! 🙂 Link to comment https://www.classiczcars.com/forums/topic/66171-seating-brake-line-fittings/?&page=2#findComment-633446 Share on other sites More sharing options...
January 20, 20223 yr Author comment_634519 Hi All, All good info, thank for your input. Classic Tube sold me a single replacement line, understood there could be a bad line within the kit. . Dutchzcarguy great tip with phone / camera when visibility is impossible without removing the entire block. Cleaned up the internal cone and installed the new fitting/ line, leak gone :). Link to comment https://www.classiczcars.com/forums/topic/66171-seating-brake-line-fittings/?&page=2#findComment-634519 Share on other sites More sharing options...
January 20, 20223 yr comment_634522 Super! Link to comment https://www.classiczcars.com/forums/topic/66171-seating-brake-line-fittings/?&page=2#findComment-634522 Share on other sites More sharing options...
February 3, 20223 yr Author comment_635318 Hi All, Getting close to turning the key with the new intake. Question about air temp sensor placement and fitment. Sensor Fitment - The air box is fiberglass see pic. Is there a source for plastic threaded sensor bungs that would glue into the box? Sensor placement - Where would be the ideal air temp sensor placement, inlet or rear of the box? 4" air inlet, Has anyone routed a flex hoses through the front body/radiator brace? It's getting tight up front. Send pics please. Thanks, Link to comment https://www.classiczcars.com/forums/topic/66171-seating-brake-line-fittings/?&page=2#findComment-635318 Share on other sites More sharing options...
