I need to remove the lock ring from the 240Z fuel tank, and I thought I would do a search to see if there is a tool to do that. Google sent me down several interesting rabbit holes in this quest.
I noticed that the lock ring for the older Mustangs looked pretty similar to the one for the 240Z. That ring was cheap, so I ordered one.
It is slightly larger than the 240Z ring. Many older GM cars/trucks have a very similar style and size, too.
The locking ring tools may work, but I didn't feel like ordering one.
Here are a couple I found:
http://blog.virginiaclassicmustang.com/2020/09/gas-tank-sending-unit-lock-ring-tool.html
https://www.ecklers.com/fuel-sending-unit-lock-ring-tool-25-255042-1.html
One of the other rabbit holes I explored was the Honda/Acura lock ring from the 90s. Once I found the Ford lock ring was too large, I thought that the Honda one might be closer due to metric system stuff.
I found the Dorman 579-015 on Amazon: https://www.amazon.com/dp/B002D3Y30U. At that price, I figured it was worth a look.
A new Z lock ring from ZCarDepot is on the left. The Honda lock ring seems to have the same inner and outer diameters as the Z lock ring. It only has 3 inner tabs as opposed to the 4 on the Z lock ring.
I plan on trying the lock ring on an old tank in the near future to verify fit. Given that the 240Z lock rings are cheaper, there isn't a need to switch, but we never know when supply will dry up.
As for a lock ring tool, I decided to make one myself.
A friend who has worked on a lot more Z cars than I have told me he made a similar one.
https://www.classiczcars.com/forums/topic/66181-fuel-tank-sender-lock-ring/
Flat blade screw driver and hammer has always worked for me. Tap one tab, then next, it comes off.
I did make a tool to help, which it does, especially when the tank is still in the car. Based on a short 2” steel pipe nipple that I welded little tabs on that hit on those four little tabs. Then added a bar and 17mm nut welded in the center to put a socket or wrench on. Great if you have a welder.
Interesting that the Honda ring is so similar. Good find.
I like that idea. It's easy to find the 2 inch pipe and caps in iron around here.  I didn't want to use the screwdriver and hammer because the tank is in the car and half full of gas. I have an aversion to mixing sparks and gasoline vapors.
36 minutes ago, dmorales-bello said:
I described a tool I made especially for that task using pvc tubing. I couldn't come up with the link in my search but perhaps one of the guys here remembers it.
Sent from my SM-N986U using Tapatalk
I found it. I like that idea, too.
I agree. Very simple and works! If you don’t want sparks, you can use a hard plastic material or wood dowel…..doesn’t take many pops with a hammer to “git her done!”
Edited by Diseazd
Here's the follow-up.
I made a tool like @dmorales-bello did out of a Schedule 40 threaded cap. The downside is that it didn't fit with the tank strap in place. The good news is that the angle iron tool I made worked very well.
It looks like I pinched the o-ring on the sender when I installed it. I used a new o-ring, and I haven't seen a leak.
I tried the Dorman lock ring on my old tank. It had to rotate to the bump to have enough pressure to stop moving.
I definitely prefer the Nissan lock rings, but it's good to know of alternatives should the good ones dry up.
