Posted January 22, 20223 yr comment_634677 My brakes are dragging. Is this because I’ve been using my emergency brake when parking? What do I need to do to fix it? Link to comment https://www.classiczcars.com/forums/topic/66276-brakes-dragging/ Share on other sites More sharing options...
January 22, 20223 yr comment_634680 Using the emergency brakes shouldn't make them drag. Brake shoes not returning could do it or brake cylinders corroded and not returning could do it... Those are my first thoughts Link to comment https://www.classiczcars.com/forums/topic/66276-brakes-dragging/#findComment-634680 Share on other sites More sharing options...
January 22, 20223 yr Author comment_634688 Any other thoughts. I want to get all the ideas together before I start tearing into it. Link to comment https://www.classiczcars.com/forums/topic/66276-brakes-dragging/#findComment-634688 Share on other sites More sharing options...
January 22, 20223 yr comment_634700 Could be corrosion in the cable not letting it fully release. Not sure how the set up is on earlier Z’s though Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/66276-brakes-dragging/#findComment-634700 Share on other sites More sharing options...
January 22, 20223 yr comment_634701 From what you say I'm guessing it's the rear brakes. I you decide it's the wheel cylinders and you want to replace them you can use the newer cylinders with some minor brake line tweaking on the back of the drums. Here's a thread I did when I replaced mine. Link to comment https://www.classiczcars.com/forums/topic/66276-brakes-dragging/#findComment-634701 Share on other sites More sharing options...
January 22, 20223 yr Author comment_634718 From what you say I'm guessing it's the rear brakes. I you decide it's the wheel cylinders and you want to replace them you can use the newer cylinders with some minor brake line tweaking on the back of the drums. Here's a thread I did when I replaced mine. Left rear brake is stuck. I jacked it up, the brakes are so tight I can’t turn the tire at all? I’m not sure where to start. I loosened the brake like at the cylinder to see if it would loosen up, no luck. I used a rubber mallet to see if I could break it loose, again no luck. I guess I need a big wheel puller, right? Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/66276-brakes-dragging/#findComment-634718 Share on other sites More sharing options...
January 22, 20223 yr comment_634722 Before you do that, you need to back off the adjuster. You should be able to find procedures for that on here. The brake-drum puller should be used only after you have done that. Link to comment https://www.classiczcars.com/forums/topic/66276-brakes-dragging/#findComment-634722 Share on other sites More sharing options...
January 22, 20223 yr Author comment_634724 Before you do that, you need to back off the adjuster. You should be able to find procedures for that on here. The brake-drum puller should be used only after you have done that.I can’t turn the hub to the point where I can access the adjuster. It won’t move at allSent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/66276-brakes-dragging/#findComment-634724 Share on other sites More sharing options...
January 22, 20223 yr comment_634729 Did the wheel move while on the ground? If so, get a reference of where you need the wheel and mark it then put the wheel back on and move it to the right spot. Or you could try a long pry bar between two wheel studs. Maybe wrap them in tape to protect the threads Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/66276-brakes-dragging/#findComment-634729 Share on other sites More sharing options...
January 22, 20223 yr Author comment_634730 Great ideas. Thank you Link to comment https://www.classiczcars.com/forums/topic/66276-brakes-dragging/#findComment-634730 Share on other sites More sharing options...
January 22, 20223 yr comment_634733 Is the Ebrake cable pulled at that wheel or is there slack right there adjacent to the hub? Link to comment https://www.classiczcars.com/forums/topic/66276-brakes-dragging/#findComment-634733 Share on other sites More sharing options...
January 22, 20223 yr Author comment_634734 Is the Ebrake cable pulled at that wheel or is there slack right there adjacent to the hub?I disconnected the e brake Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/66276-brakes-dragging/#findComment-634734 Share on other sites More sharing options...
