Posted January 23, 20223 yr comment_634776 Guys, i bought a 77 Auto over a year ago and car was sitting for 3-5 years. It does need a wash!!! I stumbled upon somewhere in the manual that says do not steam clean the engine. Is anyone aware of this? I am not able to find that again. Right now I am just planning to use some good of the shelf solvent and wash normally. Is there something I need to be careful about and prevent water to it? Appreciate some input. Â Link to comment https://www.classiczcars.com/forums/topic/66283-cleaning-the-engine-bay-77-280z-auto/ Share on other sites More sharing options...
January 23, 20223 yr comment_634782 Yes, the black plastic box on the side of the afm and the other smaller on. The TPS. I would also cover the distributor somehow. Â Link to comment https://www.classiczcars.com/forums/topic/66283-cleaning-the-engine-bay-77-280z-auto/#findComment-634782 Share on other sites More sharing options...
January 23, 20223 yr comment_634783 Here's my biggest time saver for my '77. He's done it all already. Click on "electrical" and also "efi and fuel". Good stuff to read through and even better camera work. Thanks @240260280 https://www.atlanticz.ca/zclub/techtips/ Link to comment https://www.classiczcars.com/forums/topic/66283-cleaning-the-engine-bay-77-280z-auto/#findComment-634783 Share on other sites More sharing options...
January 23, 20223 yr comment_634784 Those are good posts. I was going to say "every electrical connection". Be prepared to replace the injector connectors if you haven't already. There are much better out there, available at any wrecking yard from Chevys, Volvos, BMW,s etc.  Link to comment https://www.classiczcars.com/forums/topic/66283-cleaning-the-engine-bay-77-280z-auto/#findComment-634784 Share on other sites More sharing options...
January 24, 20223 yr comment_634792 I would recommend you stay away from cleaning with any kind of flowing water, If you must clean just use a damp cloth with some warm soapy water and wipe down where you want to clean. The engine does not care to be clean, except if you plan to open something up and there is a dirt that could get the engine internals. I hose down areas like that with brake clean. It dries quickly and cuts grease and oil. Use it liberally and you can just let he dirt wash off. Edited January 24, 20223 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/66283-cleaning-the-engine-bay-77-280z-auto/#findComment-634792 Share on other sites More sharing options...
January 24, 20223 yr comment_634794 Brake cleaner? That's pretty strong stuff. I like the "low and slow" approach like barbecue. Â Link to comment https://www.classiczcars.com/forums/topic/66283-cleaning-the-engine-bay-77-280z-auto/#findComment-634794 Share on other sites More sharing options...
January 24, 20223 yr comment_634795 6 minutes ago, siteunseen said: Brake cleaner? That's pretty strong stuff. I like the "low and slow" approach like barbecue. Â works great I use it all the time with no issues, super clean, nice when looking for oil leaks etc as well. Main point is water is not good as it can promote corosion if not dried well. Its easy to over love an engine by thinking it needs to be all shiny, inside is what matters, this is for the OP as far as engine cleaning goes. Edited January 24, 20223 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/66283-cleaning-the-engine-bay-77-280z-auto/#findComment-634795 Share on other sites More sharing options...
January 24, 20223 yr comment_634796 Yes. Some, or most, brake clean sprays are pretty wicked. They will remove cheaper paints, and stain others and maybe worse on plastics.Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/66283-cleaning-the-engine-bay-77-280z-auto/#findComment-634796 Share on other sites More sharing options...
January 24, 20223 yr comment_634797 OP one thing to watch out for, oven cleaner, there are some folks on internet that use this stuff, esp to clean alum, not a good idea, as it will dull and grey the finish and just not needed. Link to comment https://www.classiczcars.com/forums/topic/66283-cleaning-the-engine-bay-77-280z-auto/#findComment-634797 Share on other sites More sharing options...
January 24, 20223 yr comment_634798 1 minute ago, mailnome said: Yes. Some, or most, brake clean sprays are pretty wicked. They will remove cheaper paints, and stain others along and maybe worse on plastics. Sent from my iPhone using Tapatalk guess I must be the exception here, never had that problem. Link to comment https://www.classiczcars.com/forums/topic/66283-cleaning-the-engine-bay-77-280z-auto/#findComment-634798 Share on other sites More sharing options...
January 24, 20223 yr comment_634799 Brake parts cleaner used to be chlorinated solvents. Today's common ones are petrochemicals. Might explain the difference. https://www.berrymanproducts.com/chlorinated-vs-non-chlorinated-brake-cleaner/#:~:text=Berryman Chlorinated Brake Parts Cleaner,best cleaning for brake parts.  Edited January 24, 20223 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/66283-cleaning-the-engine-bay-77-280z-auto/#findComment-634799 Share on other sites More sharing options...
January 24, 20223 yr comment_634801 I use lots of brake clean. I buy ot by the case. I have found it can remove some paints but that's pretty rare. It can also hurt some plastics. Now dont confuse that with carb cleaner!! I have found carb cleaner to be super aggressive at damaging paints and plastic Link to comment https://www.classiczcars.com/forums/topic/66283-cleaning-the-engine-bay-77-280z-auto/#findComment-634801 Share on other sites More sharing options...
