AFM (77 280z Auto)
MH77280Z
Hi,
I was bench testing an AFM. I get around 225ohm between 6 & 8 and 125ohm between 8 & 9.
Has anyone seen this? does it mean it is too much and it requires cleaning and re-calibration?
https://www.atlanticz.ca/zclub/techtips/afm/index.html
Measure the resistance from the high side to the low side of the pot/copper trace. (Pins 8 and 6). It should read ~180ohm
Measure the resistance across the "standard"/"Reference"/"Control" resistor. (Pins 8 and 9). It should read 100ohms
  • Who's Online   2 Members, 1 Anonymous, 830 Guests (See full list)
