Hi Friends,
Clean gas tank, new bench tested injectors, all new injector connectors, also changed connectors to themo time, temp sensor, cold start valve is new and so is the harness connector. The car runs well after it warms up in 1-2 mins of idle.
Cold start is giving me issues, the engine sputter and try to die. If you pump the gas it is uneven, sometimes it suddenly jumps to very high rpm, i mean u really have to keep pumping the paddle to get it running.
We are thinking AFM? TPS? or anything else? any experiences you can share?
Edited by MH77280Z
10 minutes ago, MH77280Z said:
We installed a new Standard Motors cold start valve. I can clean the bullet connectors but what does that mean? do u suspect the injector is not working due to corroded connections etc.?
You can pull it and it put in a glass container and see how much it fills. Like s30driver says it only comes in at start up but they do leak when their bad adding fuel. They're on the same 30lb something high pressure side of the pump. On cleaning the bullet connections I say shine up all connections. It won't take long and cost nothing.
Here's the main thought on shing up old connections.
https://www.atlanticz.ca/zclub/techtips/electricalconnections/index.html
any time you have a cold running issue that goes away at warm up you need to check the water temp sensor resistance while the engine is cold AT THE 35 PIN CONNECTOR.
read the fsm on what you should see. perhaps you have already done this.
When u say 35 pin connector - where is that? Appreciate everyone’s patience 🙂
@Dave WM I looked at the diagram and the pins labeled on the water temp sensor are 13 and 49 I believe. What is a 35 pin connector?
There is one more observation today ...
I cranked the car cold and rpms were abrupt and i had to keep the paddle pumping to keep it alive and sometimes it went to high RPM (as expected) but within 1 min of running and sputtering like this it suddenly smoothed out. I am very sure the engine was NOT at operating temperature. So something got corrected during that 1 min...
Dont hate me for it guys ... what do you think?
My recommendation is to go back to the EFI section of the AFM. Start at the beginning and work your way through it recording every reading you get with your meter. Make notes and work through it. Chances are it’s multiple issues you are dealing with. There’s not a simple answer for these antiquated EFI cars. The more you check the more you will learn what makes the system tick. A lot of patience. Wish I had a better answer for you.
24 minutes ago, MH77280Z said:
rpms were abrupt
Not clear what this means but if the tachometer needle does not seem to match engine RPM correctly that is a sign of an ignition module problem.
If banging on the ECU clears up the rough running, that's an ECU problem.
Recently Browsing 0
