Wires near front gas tabk
Wally
thanks. It appears both caps are unusable they wont fit and stay in place. Thus i guess they came off. I can replace those easy enough.
I have the tank virtually empty, maybe 1/4 gallon or less in it. Is this an item recommended to replace when you are refreshing a datsun
or move of a leave it alone unless its broke?
The caps only hold on the wires to a limited extent. If the connectors are bent, they won't hold well, either. I think Eastern Beaver had the caps. Maybe someone can recall them being sold by a business in the USA.
If the vent hoses are rotting and you try to fill the tank, it will start spewing like a frat boy on his 25th beer. Do your research. Most of the vent hoses are NLA. You'll need to find fuel compatible hoses of the correct size. Do NOT use heater hose for the vent lines. You can get an idea of the routing of the vent lines from the FSM.
  • Who's Online   2 Members, 0 Anonymous, 967 Guests (See full list)
