headlight case to front fender
qz16
Thanks for the quick response.
Since the part is discontinued, I guess I have 3 options:
   1. live without the gasket - probably not a good idea - paint will probably chip
   2. get the rubber gaskets that go behind the headlight bucket and modify them
   3. make something out of rubber or that flexible sealer used for an RV.  I think Wick Humble (How to Restore ....") calls the stuff dumdum.
If you have any other suggestions don't hesitate.
Anyway, I appreciate the help - thanks.
Regards,
ron
ps - I just remembered what the real name is for dumdum - Its a seam sealer, comes stuck to a sheet in a roll.  I have used to seal an AC on a RV roof, seemed to work.
Edited by qz16
30 minutes ago, SteveJ said:
I believe those ones go between the inside of the fender and the in inner dome shaped headlight bucket for the bulb. That one is also available from vintage rubber. The one we are looking for goes between the front of the fender and the back of the headlight case aka sugar scoop.
  • Agree 1
Thank you for clarifying. I wasn't paying close enough attention to the picture you posted. That's what I get for trying to read when I'm tired. LOL
okay so, I looked in the garage and the stuff that I was talking about is called butyl tape.  I dont think seam sealer would be a good idea because I think it has adhesive.
Does anyone know what the original packing was made from?
