can anyone confirm the type of screw used in the middle of the piller trim? I think i see a screw and washer (machine screw) but mine is missing so now sure.
its the only place that has a small hole on the trim piece the rest uses the rivnuts (plastic).
Dave, I have a 1971 series 1 car, so not sure if what I have would be the same for your 280z.
the original trim screw for my car is a black oxide, self tapping, oval head Philips screw.  The
finish washer is a clear plastic rounded, or dished washer.  The screw measures approx 9mm
of thread length with a total length of approx 13mm.  See photos below.
Hope this is what you are looking for.
Thanks for posting this, my 1970 has the exact same screw and washer on the right side, but it has a self tapping screw on the left side that has an integral washer. Now I know which is correct.
Strange that this screw and washer is not documented in the parts book.
