Posted February 16, 20223 yr comment_635984 I'm sure this has been discussed on here before but I can't find a way to search the forum. Anyways, my driver side mirror wiggles just a bit and it looks like unless you have long skinny alien fingers there seems to be no room to reach the nut. Is there a special tool or trick? Sorry, forgot to mention this is on a 1977 280z with what look like a factory mirror. As always, appreciate any help. ย Thanks! ย Ryan Link to comment https://www.classiczcars.com/forums/topic/66355-loose-driver-side-mirror/ Share on other sites More sharing options...
February 16, 20223 yr comment_635985 Oh your hands gonna get jacked up. ย It might be easier to remove the window and tighten it up, maybe dab some thread adhesive. If you remove the window you get a shot at cleaning the rails too. If the rubber insulator is messed up between the mirror and the body itโs a great time to fix that too.ย Link to comment https://www.classiczcars.com/forums/topic/66355-loose-driver-side-mirror/#findComment-635985 Share on other sites More sharing options...
February 16, 20223 yr Author comment_635986 @heyitsramaย Thanks for the quick response. Man, sounds like a full on job now haha! Was hoping there was a trick to this. Edited February 16, 20223 yr by FresnoZ Link to comment https://www.classiczcars.com/forums/topic/66355-loose-driver-side-mirror/#findComment-635986 Share on other sites More sharing options...
February 16, 20223 yr comment_635987 1 minute ago, FresnoZ said: @heyitsramaย Thanks for the quick response. Man, sounds like a full on job now haha! Was hoping there was a trick to this. There is a trick, have someone with small hands do it for you ๐ Link to comment https://www.classiczcars.com/forums/topic/66355-loose-driver-side-mirror/#findComment-635987 Share on other sites More sharing options...
February 16, 20223 yr Author comment_635989 @heyitsramaย Haha I have four kids under the age of nine but I canโt pay them enough in candy to help me Link to comment https://www.classiczcars.com/forums/topic/66355-loose-driver-side-mirror/#findComment-635989 Share on other sites More sharing options...
February 17, 20223 yr comment_635999 I had the same thing and have big hands. I went on Amazon and bought one of those cheap foot long flexible extensions and managed to get my socket onto it and snugged it up. It was not easy but I managed to get it to work. ย Link to comment https://www.classiczcars.com/forums/topic/66355-loose-driver-side-mirror/#findComment-635999 Share on other sites More sharing options...
February 17, 20223 yr Author comment_636000 @Casey_zย yes! I will definitely give this one a try ๐๐ Link to comment https://www.classiczcars.com/forums/topic/66355-loose-driver-side-mirror/#findComment-636000 Share on other sites More sharing options...
