February 18, 20223 yr comment_636042 Well you said it ran better all the way up so that explains the yellow part. I would make sure the nozzles are completely up. That flat bar Mark spoke of can get out of shape and keep them from reaching their height and lessening the fuel. Have you a way to meter the air flow, balance that? These are great and fairly cheap. Well after googling it there not so cheap anymore? https://www.amazon.com/Latest-Rage-5385730856-Carburetor-Airflow/dp/B00CMC57R0/ref=pd_aw_fbt_img_2/140-4982961-2615742?pd_rd_w=Xlzjj&pf_rd_p=76328f70-5fff-49b7-869a-94bfdaa768fc&pf_rd_r=JECHWPJ6RGT64TVVHVNZ&pd_rd_r=42368007-404a-49b9-87a3-cbbfc73c54b5&pd_rd_wg=n1J8w&pd_rd_i=B00CMC57R0&psc=1 I agree with Steve and Zed, a good tune 1st. When I got mine the best running ever I had my timing full advance at 17 at idle then the dial back set on 34. At 2,500 rpm it sits at 0 on my light. BUT! I have a ZX electronic distributor. Love the old car but the simplicity was increased with the newer ZX dizzy. Link to comment https://www.classiczcars.com/forums/topic/66356-gunson-colortune-always-yellow/?&page=2#findComment-636042 Share on other sites More sharing options...
February 18, 20223 yr comment_636043 2 minutes ago, SteveJ said: That's what @240260280 taught me to do. Me too! Link to comment https://www.classiczcars.com/forums/topic/66356-gunson-colortune-always-yellow/?&page=2#findComment-636043 Share on other sites More sharing options...
February 18, 20223 yr Author comment_636044 Thanks to all. Based on all of the advice here's my plan: Install electric points and new coil Rebuild carbs. I don't know the current status of the carbs, so rebuild is in order. Wrap my headers to reduce temps - I don't have space for a heat shield between the header and the intake manifold. Adjust the valves Set the timing Adjust the carbs - to include balance and Colortune Take her for a spin I will definitely read the '72 FSM and use as my guide. Link to comment https://www.classiczcars.com/forums/topic/66356-gunson-colortune-always-yellow/?&page=2#findComment-636044 Share on other sites More sharing options...
February 18, 20223 yr comment_636045 Thanks to our buddy Hoover here's a good read. Once you wrap your head around this it all falls in place. The "ah ha" for me. Link to comment https://www.classiczcars.com/forums/topic/66356-gunson-colortune-always-yellow/?&page=2#findComment-636045 Share on other sites More sharing options...
February 18, 20223 yr comment_636049 "Electronic ignition" is what you mean by "electric points". The points are already electric. What type will you be installing? there are many. Interesting that people suggested 1, 2, 3, 4 and you said okay my plan is 3, 2, 4, 5. Nothing wrong with doing your own thing, just interesting. Good luck. Link to comment https://www.classiczcars.com/forums/topic/66356-gunson-colortune-always-yellow/?&page=2#findComment-636049 Share on other sites More sharing options...
February 18, 20223 yr Author comment_636051 @Zed Head I truly appreciate your observation, and I do try to follow the recommendations. I'm waiting on the carb rebuild kit, so can't do that yet. I added my rationale (in bold) to each of my points below: Install electric points and new coil - I received this the other day, so thought I'd install it. Rebuild carbs. I don't know the current status of the carbs, so rebuild is in order. - I really do think the carbs are part of the problem, so thought it would be good to know it's done right. I'm not sure when the kit will arrive. Wrap my headers to reduce temps - I don't have space for a heat shield between the header and the intake manifold, so I'm concerned that the heat from the header could be an issue. I don't have any real knowledge in this area it's just a hunch. Based on what you guys have recommended, I believe the next three steps are in the correct order... Adjust the valves Set the timing Adjust the carbs - to include balance (with airflow meter) and Colortune. The pic is a little device I rigged during my MGB days. The end that contacts the carbs bends to accommodate tight spaces. Take her for a spin and adjust as needed. Edited February 18, 20223 yr by HappyZ Link to comment https://www.classiczcars.com/forums/topic/66356-gunson-colortune-always-yellow/?&page=2#findComment-636051 Share on other sites More sharing options...
March 13, 20241 yr comment_663070 I know you have the choke cables disconnected, but just make sure they aren't sticking closed. Had this happen on my '71, and it drove me crazy. Link to comment https://www.classiczcars.com/forums/topic/66356-gunson-colortune-always-yellow/?&page=2#findComment-663070 Share on other sites More sharing options...
March 13, 20241 yr comment_663083 What kind of gas are you using? I thought I read somewhere that the colortune does not work with ethanol gas. Link to comment https://www.classiczcars.com/forums/topic/66356-gunson-colortune-always-yellow/?&page=2#findComment-663083 Share on other sites More sharing options...
March 13, 20241 yr comment_663085 This post is over 2 years old. Link to comment https://www.classiczcars.com/forums/topic/66356-gunson-colortune-always-yellow/?&page=2#findComment-663085 Share on other sites More sharing options...
March 13, 20241 yr comment_663088 Thanks, Yarb. I saw the Feb date but not the year. lol Link to comment https://www.classiczcars.com/forums/topic/66356-gunson-colortune-always-yellow/?&page=2#findComment-663088 Share on other sites More sharing options...
