Posted March 9, 20223 yr comment_636988 I am going to replace the timing chain and related components. Its on an engine stand, oil pan off, head on. Any tips or tricks I should know? Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/ Share on other sites More sharing options...
March 9, 20223 yr comment_636994 follow the instructions in the book. How to Rebuild Your Nissan & Datsun Ohc https://www.amazon.co.uk/dp/1931128030/ref=cm_sw_r_cp_apan_glt_i_9V7X0J9VS8R27RZTFBM6?_encoding=UTF8&psc=1 Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/#findComment-636994 Share on other sites More sharing options...
March 9, 20223 yr comment_636995 Put a zip-tie around the new tensior to keep it together while you get the chain on. I could only find a ZX kit when I built my 2.4. Worked great but it has different hole spots on the guides. I used the inner holes and got the chain really snug. From what I read you shouldn't be able to see any of the metal on the tensioner when it's all together. Get a new oil pump while you're at it. Edited March 9, 20223 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/#findComment-636995 Share on other sites More sharing options...
March 10, 20223 yr comment_637026 Put it on TDC before you touch anything. Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/#findComment-637026 Share on other sites More sharing options...
March 13, 20223 yr Author comment_637173 It says in the fsm that there are 42 "links" between marks. I have 20 "links" = 40 pins plus one on either link to the sprocket marks = 42. Is that the right was to look at it? mine were also in hole #1. I am replacing with new parts. Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/#findComment-637173 Share on other sites More sharing options...
March 13, 20223 yr comment_637174 On 3/9/2022 at 11:19 PM, Yarb said: Put it on TDC before you touch anything. ………TDC Compression stroke. Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/#findComment-637174 Share on other sites More sharing options...
March 13, 20223 yr comment_637175 1 hour ago, ennisdavis said: It says in the fsm that there are 42 "links" between marks. I have 20 "links" = 40 pins plus one on either link to the sprocket marks = 42. Is that the right was to look at it? mine were also in hole #1. I am replacing with new parts. The shiny links will be on the same dot or number corresponding with the cam spocket and crank. Don't forget your oil slinger when you go to putting it back together. Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/#findComment-637175 Share on other sites More sharing options...
March 13, 20223 yr Author comment_637177 New chain is a Mellings, no shiny links. Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/#findComment-637177 Share on other sites More sharing options...
March 14, 20223 yr Author comment_637218 I think when everyone says 42 links, they mean roller pins. There are only 20 "links" between the marks. Double that =40, add 4 =44. Does not add up Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/#findComment-637218 Share on other sites More sharing options...
March 15, 20223 yr comment_637221 If your sprocket has the notch in it you can just use the notch and groove. Keep the tight side tight. Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/#findComment-637221 Share on other sites More sharing options...
March 15, 20223 yr Author comment_637245 Don't see a groove in sprocket. Tight side is driverside of engine, right? Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/#findComment-637245 Share on other sites More sharing options...
March 15, 20223 yr comment_637269 The groove is on the rear hub facing the windshield. Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/#findComment-637269 Share on other sites More sharing options...
