March 16, 20223 yr comment_637325 On 3/15/2022 at 12:47 PM, ennisdavis said: Don't see a groove in sprocket. Tight side is driverside of engine, right? Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/?&page=2#findComment-637325 Share on other sites More sharing options...
March 20, 20223 yr Author comment_637466 Don't have a notch in the mellings sprocket but I see what you are saying. The tight side has the tensioner right. Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/?&page=2#findComment-637466 Share on other sites More sharing options...
March 20, 20223 yr comment_637467 The tight side is the one that doesn't need the tensioner. The crank pulls the chain down clockwise from the front so from the front of the car the tight side is the right or straight side. Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/?&page=2#findComment-637467 Share on other sites More sharing options...
March 20, 20223 yr comment_637470 It's off a little I think. The front pulley key slot should be straight up. Like this your mechanical timing would be retarded? or PC correct, "slow" coming in. Edit: I just realized the motor is tilted pretty good so maybe it's right. Edited March 20, 20223 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/?&page=2#findComment-637470 Share on other sites More sharing options...
March 20, 20223 yr Author comment_637478 There are 42 pins between marks like the fsm states. It is what it is. All parts are new. I have not turned it over but I wonder if the drivers side will tighten. Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/?&page=2#findComment-637478 Share on other sites More sharing options...
March 20, 20223 yr comment_637479 Everything seems pretty well installed, but it's just hard to tell if the cam is oriented correctly. Weird that the aftermarket companies have removed all of the marks needed to ensure proper installation. Is there a mark on the lower sprocket? I looked at the images on Rockauto and couldn't tell. They might be showing the backside. Edit - I think I see it now. Edited March 21, 20223 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/?&page=2#findComment-637479 Share on other sites More sharing options...
March 20, 20223 yr comment_637480 There's probably a cam lobe at a certain point when things are right that you could use instead of the marks. Just about to get on the ramp or straight up, or something. Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/?&page=2#findComment-637480 Share on other sites More sharing options...
March 21, 20223 yr comment_637484 Here's a Hybridz link with a youtube video. The guys that posted in it are some of the smart engine building guys. Might give you some ideas and the video has good images of the marks and the links. He has dark links. https://forums.hybridz.org/topic/129303-matching-cam-crank-timing/ Time-stamped the video. Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/?&page=2#findComment-637484 Share on other sites More sharing options...
March 23, 20223 yr Author comment_637593 Couple of issues with that video. Obviously an amateur with no L28 experience. Puts the upper chain sprocket on with the chain and then realizes he cant get it on. Thats auto mechanics school 101. But any way is 13:12 he adjusts the upper cam to the mark and the chain still is slightly loose on the drivers\ side like mine. Then in 13:27 its mysteriously tight. If I turned my crank a bit it would be tight too. BUT.... the pulley would not be at TDC. 42 pins mark to mark and the sprockets are locked, I dont see how you could adjust anything. Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/?&page=2#findComment-637593 Share on other sites More sharing options...
March 23, 20223 yr comment_637598 On 3/23/2022 at 11:58 AM, ennisdavis said: Obviously an amateur with no L28 experience. The video had some tips and tricks. Obviously, you are well past this step. Don't forget to use good break-in oil on the first engine start. The cam lobes are sensitive. Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/?&page=2#findComment-637598 Share on other sites More sharing options...
March 26, 20223 yr Author comment_638577 Is there an other way to tighten the cam shaft bolt to 100ft lb without holding the center of the camshaft. I really dont want to screw up the camshaft. Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/?&page=2#findComment-638577 Share on other sites More sharing options...
March 26, 20223 yr comment_638578 Pull the starter…..get someone to lock the flywheel by inserting a large screwdriver in a gear tooth and rotating till it rests against the engine block. Are you sure about 100 ft lbs? Sounds high. I think some manuals call for less. Edited March 26, 20223 yr by Diseazd Link to comment https://www.classiczcars.com/forums/topic/66416-l28-timing-chain/?&page=2#findComment-638578 Share on other sites More sharing options...
