I have a 1995 240sx transmission in my 280z and am in the process of rebuilding it. I need to replace the front bearing on the counter shaft. It is a 62 x 22 x 17mm bearing. It is a Nachi bearing which is the original bearing for the trans. I would like to replace it with a new Nachi bearing but I just can't go to a Nachi bearing distributor and order it. It is a proprietory bearing made just for Nissan and must be purchased thru them. I called Courtesy Nissan and they want to know the VIN num. on the car which I don't have because I only purchased the trans. Does anyone know the part number for the front bearing on the countershaft for this 5 speed. The number on the bearing is a 22BC06S5X.
I have already looked into getting a German bearing (Fafnir, NGK, etc.) but the ID of this bearing (the 22 mm) is not manufactured by anyone except Nachi.
I don't know of any quality manufacturer of bearings that I can turn to in order to get my trans back together.
https://www.classiczcars.com/forums/topic/66434-part-num-needed/
In case you need to look at the service manual for a 240SX for more info on putting it back together (or names of parts) - https://forums.nicoclub.com/nissan-240sx-factory-service-manuals-for-nicoclub-members-t549156.html
Sorry, Zed Head, I should have passed the info on. Midwest Transmission Center. They have complete rebuild kits as well as individual parts, synchros, bearings, gaskets, seals, and etc.
Midwest Transmission Center, Inc. - Your Transmission, Transfer Case and Differential Drivetrain Experts
1 hour ago, Zed Head said:
It was right there in SteveJ's second link.
Yes. I saw the nicoclub link, but missed the nissanpartsdeal link. Didn't know that site was still working.
My post was actually meant for Cruzzar, he's the one that would have/should have clicked the link to see what SteveJ offered.
I wonder the difference is between the original and the replacement?
