New build, engine wants more ignition timing, but I'm scared of knock....
I have a 123 distributor with a Bluetooth app I can set any timing I want.
engine specs: l26 N42 head new stock bearing and rings.
Schneider stage 3 460 lift 280 dur. timed 5 degrees adv to spec
dual weber 32/36 dgv, I have a jet kit but need to get my o2 sensor working
pacesetter headers 2.5in exhaust
really good ignition components
kameari twin idlers and adjustable cam gear
3 core rad with dual 12 in fans for cooling. heat shielding everywhere.
a video of it running
Edited by youztheclue
An N42 on flat tops will be up there, higher, in CR.  But, usually, full timing is in by 2500 RPM, so you might be a little bit cautious.  Your MAP curve (vacuum advance) seems a bit odd also, you might look at some examples from the FSM to see what Nissan does.  @madkaw has done some tuning on performance engines, as well as @Diseazd and other that I can't remember right now.
These are for 1973
WHOA !
you don’t want that much vacuum advance( map curve) added on top of your base timing . You have your numbers reversed  . With speed density system the kpa increases with load . So instead of adding timing during cruise( lower kpa) , you are adding during timing during heavy loading
Have you studied the factory curves?  Vacuum advance disappears pretty quickly, and it's only vacuum (pressure based).
Does the software allow you to change units?  It will make things easier.  There are conversion charts.  I'd match a factory setup and then tune from there.
https://www.vacuum-guide.com/english/equipment/conversion_pascal_bar.htm
https://www.engineeringtoolbox.com/vacuum-converter-d_460.html
