Posted March 20, 20223 yr comment_637458 Combing through my laundry list of odds and ends, noticed my carb linkage has a floating plate looks like a mod for sure, was just wondering if this is a problem ? I have a lot to learn and I appreciate any and all input ! Link to comment https://www.classiczcars.com/forums/topic/66484-modified-su-carb-linkage/ Share on other sites More sharing options...
March 20, 20223 yr comment_637459 That side hooks up to the emissions components that normally sit on top of the balance tube where the bolts are not holding anything. Most have been removed long ago. Link to comment https://www.classiczcars.com/forums/topic/66484-modified-su-carb-linkage/#findComment-637459 Share on other sites More sharing options...
March 20, 20223 yr comment_637460 Missing a spinged screw but that flat is OE and has to be right or your rpms will shoot up to 2,000 on start up.  Edited March 20, 20223 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/66484-modified-su-carb-linkage/#findComment-637460 Share on other sites More sharing options...
March 20, 20223 yr comment_637461 Link to comment https://www.classiczcars.com/forums/topic/66484-modified-su-carb-linkage/#findComment-637461 Share on other sites More sharing options...
March 20, 20223 yr Author comment_637462 Ahh gotcha so the emissions portions was removed , hence the jumper hose ? Apreciate the help you guys rock . Link to comment https://www.classiczcars.com/forums/topic/66484-modified-su-carb-linkage/#findComment-637462 Share on other sites More sharing options...
March 20, 20223 yr comment_637468 Yes. You can use brass plugs to plug those extra holes for a cleaner look and less chance of the hose cracking and pulling in air. Link to comment https://www.classiczcars.com/forums/topic/66484-modified-su-carb-linkage/#findComment-637468 Share on other sites More sharing options...
March 20, 20223 yr Author comment_637471 Right that makes a lot more sense, will add that on to my list ,appreciate the insight. Edited March 20, 20223 yr by Dat.240 Link to comment https://www.classiczcars.com/forums/topic/66484-modified-su-carb-linkage/#findComment-637471 Share on other sites More sharing options...
