Help - Adding ground locations
Blitzed
Oh, I get it... I'm not unimpressed with you. I'm unimpressed with HoldPeak's annoying act of "ride the coat tails of a long-standing reputable manufacturer of similar products by conveniently coming up with a name that can easily be misconstrued by the inattentive and make them think they are buying something of higher quality and reputation".
That's what I get out of the whole naming thing.
  • 4 weeks later...
The bolt threads into a nut that's welded to the frame. It's nearly impossible to keep the threads of the bolt and nut completely isolated (insulated from each other). So, just tightening the attachment bolt through the circle connector will give a very good connection to the frame - no need to scrape any paint off.
