Downfall Posted June 18, 2003 Share #1 Posted June 18, 2003 just had my brakes bled and i do know that there is no brake fluid leaking and the brake pedal goes pretty low to the ground before it starts to work.... a mechanic told me it could be that someone changed the brake pads with out machining the rotors and that that may cause spongy feel in the pedal.....what else could it be? do i need a new brake master cylinder? Link to comment Share on other sites More sharing options...
thefastestz Posted June 18, 2003 Share #2 Posted June 18, 2003 Does it make a sound like air leaking or somthing? You could need a new brake booster.MY 280z had the brake pedal adjustment nut loose and when i pressed them they would go too low but when i saw the brake lights stay on i knew it was the adjustment and I tightened it. Link to comment Share on other sites More sharing options...
Downfall Posted June 18, 2003 Author Share #3 Posted June 18, 2003 had the brake booster changed already so i know it's not that. Link to comment Share on other sites More sharing options...
26th-Z Posted June 18, 2003 Share #4 Posted June 18, 2003 Try the rear brake adjustment just to make sure. Never hurts to check and adjust anyhow. Link to comment Share on other sites More sharing options...
Downfall Posted June 18, 2003 Author Share #5 Posted June 18, 2003 got the rear brakes adjusted as well. it made an improvement in the braking but not the pedal height. but the brakes are still not that good as they should be. Link to comment Share on other sites More sharing options...
Tak510 Posted June 24, 2003 Share #6 Posted June 24, 2003 Originally posted by Downfall got the rear brakes adjusted as well. it made an improvement in the braking but not the pedal height. but the brakes are still not that good as they should be. Have you replaced/upgraded either a master cylinder or a booster lately? If so, your push rod found in the booster could be out of adjustment. You can adjust the length of the push rod and change the pedal height. But, be very careful there! I would strongly recommend to read the Nissan manual first before dealing with that push rod. Adjusting the rod too far out will cause brakes to drag or lock up while driving. Another caution that there is a small rubber seal called "reaction disc" set right behind the push rod. This disc can easily fall inside the booster while working on the push rod. If this accident happens, you will see a new deep problem which I just gone thru... Hope this helps. Tak 72 Link to comment Share on other sites More sharing options...
