Drivers Window Kaput...
Para32
1980 280 ZX, put the drivers window fully down, and that it. The switch will not lift the window back up.
Didnt hear and clunks. Passenger side window fine.
I assume its the switch or motor in drivers side
Anything I need to be careful not to break when taking the door panel off?
You may be able to get to the switch & its wiring harness without taking the door panel off.  Carefully remove the plastic bezel around the switch without breaking the tabs and take a look.  You can possibly test the switch & power from there.
  • Agree 1
Yeah that's a problem, better take off the whole card.. when you brake a tab there it's easy to replace! and you can then get to those tabs more easely also!  It can be a lose wire or a defect switch or a motor connection,, but i don't think it's the motor as it went down well.. the glass..
