December 23, 20222 yr Author comment_648603 Charles, I would go crazy without the pictures. Text me your address and I will put them on a USB flash drive and mail them to you. Merry Christmas to you and the family!! ernest Link to comment https://www.classiczcars.com/forums/topic/67335-i-thought-i-was-done-with-z-cars/?&page=8#findComment-648603 Share on other sites More sharing options...
December 23, 20222 yr Popular Post comment_648604 The clock is very susceptible to any resistance in any part of of the gear path. I think you will find that the main drive gear is the problem. If the bearing is worn, as pictured in the attached diag., the larger gear driven by the motor is allowed to not mesh correctly with the motor drive gear. This in turn binds the all the gears in the train and the clock stops. The only way to verify this is to totally dis-assemble the clock and inspect / clean all the parts. Link to comment https://www.classiczcars.com/forums/topic/67335-i-thought-i-was-done-with-z-cars/?&page=8#findComment-648604 Share on other sites More sharing options...
December 24, 20222 yr comment_648605 49 minutes ago, zclocks said: The clock is very susceptible to any resistance in any part of of the gear path. I think you will find that the main drive gear is the problem. If the bearing is worn, as pictured in the attached diag., the larger gear driven by the motor is allowed to not mesh correctly with the motor drive gear. This in turn binds the all the gears in the train and the clock stops. The only way to verify this is to totally dis-assemble the clock and inspect / clean all the parts. I was hoping you would stumble across this thread. Link to comment https://www.classiczcars.com/forums/topic/67335-i-thought-i-was-done-with-z-cars/?&page=8#findComment-648605 Share on other sites More sharing options...
December 24, 20222 yr Author comment_648606 ZCLOCKS, thanks for insight. That would make sense. Do you repair these? Link to comment https://www.classiczcars.com/forums/topic/67335-i-thought-i-was-done-with-z-cars/?&page=8#findComment-648606 Share on other sites More sharing options...
December 24, 20222 yr comment_648607 Yes, I do repair these clocks and also convert them to quartz units. Take a look at my web site. zclocks.com Link to comment https://www.classiczcars.com/forums/topic/67335-i-thought-i-was-done-with-z-cars/?&page=8#findComment-648607 Share on other sites More sharing options...
December 24, 20222 yr comment_648614 Racer X, Forgot to mention that there are NO jeweled movements in these clocks. There are brass bushings on the ends of the shafts. Link to comment https://www.classiczcars.com/forums/topic/67335-i-thought-i-was-done-with-z-cars/?&page=8#findComment-648614 Share on other sites More sharing options...
February 15, 20232 yr Author comment_650292 Made some progress. Big thanks to @Patcon for the rottisserie. Really a great way to work. I had trouble lining up the hood/fender. I think the strut tower was tweaked in a previous accident. My plan is to paint underside, inside, and engine bay, then put it together enough to get it checked out on a frame machine. Not ideal I know, but it's the next right thing to do. Link to comment https://www.classiczcars.com/forums/topic/67335-i-thought-i-was-done-with-z-cars/?&page=8#findComment-650292 Share on other sites More sharing options...
February 23, 20232 yr Author comment_650617 Making some progress putting it back together. I didn't like the way the fender and hood fit, so I decided to paint the inside and put it together enough to get it to a frame machine. Then go after the exterior bodywork. Not the ideal, but it is the next right thing to do. Two things I have learned over the years: You cant take too many pictures and never throw anything away! One other thing, aftermarket is never as good as the original. Link to comment https://www.classiczcars.com/forums/topic/67335-i-thought-i-was-done-with-z-cars/?&page=8#findComment-650617 Share on other sites More sharing options...
February 27, 20232 yr Author Popular Post comment_650748 More progress, I put a lot of time in this weekend. Link to comment https://www.classiczcars.com/forums/topic/67335-i-thought-i-was-done-with-z-cars/?&page=8#findComment-650748 Share on other sites More sharing options...
March 13, 20232 yr Author comment_651334 I installed the dash on Sunday and discovered the VIN tag missing. Just Dashes must have removed it to paint the frame. I hope they still have it, but I doubt it. I found a vendor on Ebay that reproduces them, so I may have to go that route. I wrote myself a big fat note to avoid installing the windshield before the vin tag! Link to comment https://www.classiczcars.com/forums/topic/67335-i-thought-i-was-done-with-z-cars/?&page=8#findComment-651334 Share on other sites More sharing options...
March 13, 20232 yr Author comment_651342 I just got an email from Just Dashes, they have my VIN tag and are mailing it back with some rivets. That was lucky. Link to comment https://www.classiczcars.com/forums/topic/67335-i-thought-i-was-done-with-z-cars/?&page=8#findComment-651342 Share on other sites More sharing options...
March 26, 20232 yr Author Popular Post comment_651759 Well, they mailed back my VIN tag and it looked like they guy that drilled out the rivets was having a bad day. I ended up ordering a new one from a guy on ebay that makes them. Just Dashes agreed it was not acceptable and is reimbursing me for a new VIN tag. I really dont mind when people make mistakes, as I make plenty. It's how we handle it. Just Dashes made it right, I like that. Link to comment https://www.classiczcars.com/forums/topic/67335-i-thought-i-was-done-with-z-cars/?&page=8#findComment-651759 Share on other sites More sharing options...
