3-4 & 5Th Shift Inserts aka "Dogs" For 1983 Datsun 280ZX transmission aka Insert-Shifting, Overdrive
Looking for Shift Inserts aka "Dogs" For 1983 Datsun 280ZX transmission aka Insert-Shifting, Overdrive.  Original MFG SKU: C2609-P9501 (Discontinued)
Does anyone know if the 300zx shift inserts (SKU: 32609-23P00), link below, would work as a replacement for the 280zx?
https://www.carcraze.com.au/nissan-oem-shifter-insert-1st-2nd-nissan-300zx-z32
You could try this site. https://www.amayama.com/en/part/nissan/32609e9000
I think the parts you are quoting are for the later 300ZX transmissions. I think the only insert that fits the early models is the 5th gear. The early 83-84 model 300ZX should be the same as the 280ZX. The one with the 16mm gears.
I have ordered parts through Amayama before. All genuine Nissan parts sent from Japan. Took about three weeks to get here in NL.
  • 1 month later...
Recently Browsing 0
