Posted April 14, 20222 yr comment_639361 I am looking to install an electric cooling fan switch in the upper thermostat housing . anybody know where to purchase one, and what temp would I want for the fan to come on with a 180 degree thermostat .also what about the thread size if anybody knows that . thanks Link to comment https://www.classiczcars.com/forums/topic/67413-electric-cooling-fan-switch/ Share on other sites More sharing options...
April 14, 20222 yr comment_639362 You can buy a simple thermostat kit and the thermostat switch should fit in the position for the thermotime switch on the 280ZX thermostat housing.- Link to comment https://www.classiczcars.com/forums/topic/67413-electric-cooling-fan-switch/#findComment-639362 Share on other sites More sharing options...
April 14, 20222 yr Author comment_639363 18 minutes ago, EuroDat said: You can buy a simple thermostat kit and the thermostat switch should fit in the position for the thermotime switch on the 280ZX thermostat housing.- Link to comment https://www.classiczcars.com/forums/topic/67413-electric-cooling-fan-switch/#findComment-639363 Share on other sites More sharing options...
April 14, 20222 yr Author comment_639364 american volt sells the switch but I can't find out what the threads are. Link to comment https://www.classiczcars.com/forums/topic/67413-electric-cooling-fan-switch/#findComment-639364 Share on other sites More sharing options...
April 14, 20222 yr Author comment_639365 36 minutes ago, kully 560 said: I am looking to install an electric cooling fan switch in the upper thermostat housing . anybody know where to purchase one, and what temp would I want for the fan to come on with a 180 degree thermostat .also what about the thread size that is in the thermostat cover as I would like to install the switch there if anybody knows that . thanks Link to comment https://www.classiczcars.com/forums/topic/67413-electric-cooling-fan-switch/#findComment-639365 Share on other sites More sharing options...
April 14, 20222 yr comment_639369 I think the sizes are as follows. You should be able to find a M12 easy enough or tap the 1/4" out to 3/8" NPT. Temp gauge: M16×1.5mm Thermotime: M14×1.5mm Water temp: M12×1.5mm (for fuel injection control) Water temperature switch: 1/4" BSPT. (Not the same as NPT. Has 19 threads per inch and NPT has 18.) Link to comment https://www.classiczcars.com/forums/topic/67413-electric-cooling-fan-switch/#findComment-639369 Share on other sites More sharing options...
