Email logins are now active ×
electric cooling fan switch
kully 560
I am looking to install an electric cooling fan switch in the upper thermostat housing . anybody know where to purchase one, and what temp would I want for the fan to come on with a 180 degree thermostat .also what about the thread size if anybody knows that . thanks
36 minutes ago, kully 560 said:
I am looking to install an electric cooling fan switch in the upper thermostat housing . anybody know where to purchase one, and what temp would I want for the fan to come on with a 180 degree thermostat .also what about the thread size that is in the thermostat cover as I would like to install the switch there if anybody knows that . thanks
I think the sizes are as follows. You should be able to find a M12 easy enough or tap the 1/4" out to 3/8" NPT.
Temp gauge: M16×1.5mm
Thermotime: M14×1.5mm
Water temp: M12×1.5mm (for fuel injection control)
Water temperature switch: 1/4" BSPT. (Not the same as NPT. Has 19 threads per inch and NPT has 18.)
  • Who's Online   0 Members, 0 Anonymous, 429 Guests (See full list)
