Posted May 2, 20222 yr comment_639909 Hi All. Need some help. Replacing U Joints on my '70 240. We noticed that the half shaft flange/yoke (4 bolts) had a lot of play and were worn out. I can't find the flanges anywhere....Summit Racing might have one with the proper measurement's??? We are checking. Am I going to have to buy used half shafts and take the flanges/yokes off? Does anyone have any experience/advice with this? I would appreciate any help at all. Thank you. Link to comment https://www.classiczcars.com/forums/topic/67448-half-shaft-flangeyoke-1970-240z/ Share on other sites More sharing options...
May 2, 20222 yr comment_639915 If I understand you correctly, you are looking for part #11? The yoke? ZCarDepot has them - $40 Link to comment https://www.classiczcars.com/forums/topic/67448-half-shaft-flangeyoke-1970-240z/#findComment-639915 Share on other sites More sharing options...
May 2, 20222 yr Author comment_639916 Nope....they have them for the DRIVE shaft....I'm looking for the ones for half shaft. Link to comment https://www.classiczcars.com/forums/topic/67448-half-shaft-flangeyoke-1970-240z/#findComment-639916 Share on other sites More sharing options...
May 2, 20222 yr comment_639918 3 hours ago, Jeffrey Mader said: We noticed that the half shaft flange/yoke (4 bolts) had a lot of play and were worn out. I can't find the flanges anywhere....Summit Racing might have one with the proper measurement's??? We are checking. Am I going to have to buy used half shafts and take the flanges/yokes off? Does anyone have any experience/advice with this? What area is worn out? The yokes have a centering ring, the bolts are just for clamping. Any halfshaft through the 1983 280ZX will work. Doesn't have to be a 240Z shaft. There are differences over the years but the fitment at the ends is the same. Link to comment https://www.classiczcars.com/forums/topic/67448-half-shaft-flangeyoke-1970-240z/#findComment-639918 Share on other sites More sharing options...
May 2, 20222 yr Author comment_639919 Thank you!! This is the part.....see picture. Link to comment https://www.classiczcars.com/forums/topic/67448-half-shaft-flangeyoke-1970-240z/#findComment-639919 Share on other sites More sharing options...
May 2, 20222 yr comment_639920 Looks like it wasn't seated properly and worked its way loose, or vice-versa. Flip it over and look at the mating surface. It might be beat up. I think TerrapinZ might have some yokes. @Terrapin Z Link to comment https://www.classiczcars.com/forums/topic/67448-half-shaft-flangeyoke-1970-240z/#findComment-639920 Share on other sites More sharing options...
May 2, 20222 yr comment_639931 Yeah, I have some of those. Let me know if I can help out. Link to comment https://www.classiczcars.com/forums/topic/67448-half-shaft-flangeyoke-1970-240z/#findComment-639931 Share on other sites More sharing options...
May 2, 20222 yr comment_639932 5 hours ago, Jeffrey Mader said: Nope....they have them for the DRIVE shaft....I'm looking for the ones for half shaft. Funny, but I just noticed that 26th-Z actually described and showed the same part that you said you needed. The DRIVE shaft is the half shaft. The main one down the middle is called a propeller shaft. Not clear what your picture is of. Is it from one of the two on the sides or the one down the middle? Link to comment https://www.classiczcars.com/forums/topic/67448-half-shaft-flangeyoke-1970-240z/#findComment-639932 Share on other sites More sharing options...
May 2, 20222 yr comment_639933 Decoding and extrapolating, it looks like you want the side aka "half", shaft parts. "Drive" shaft in Nissan FSM terms. I'd get them from Terrapin, they'll be correct factory made parts. ZCD might not know exactly what they're selling. Z Car Depot does a surprisingly poor job of describing some of their parts, for being a specialty Z car store. It's not a place to go to learn the terminology. Easy to see how 26th-Z could get side-tracked. https://zcardepot.com/search?q=yoke&type=product Edited May 2, 20222 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/67448-half-shaft-flangeyoke-1970-240z/#findComment-639933 Share on other sites More sharing options...
May 3, 20222 yr comment_639936 The picture I used was not from Z Car Depot but their part may very well be from the drive shaft. I think they called it a propeller shaft yoke. Anyhow, Jeffrey, you're on the right track with Terrapin. Link to comment https://www.classiczcars.com/forums/topic/67448-half-shaft-flangeyoke-1970-240z/#findComment-639936 Share on other sites More sharing options...
May 3, 20222 yr Author comment_639949 15 hours ago, Terrapin Z said: Yeah, I have some of those. Let me know if I can help out. Hello! Yes I could use your help with this. Please contact me at 978-505-1704. Thank you. Link to comment https://www.classiczcars.com/forums/topic/67448-half-shaft-flangeyoke-1970-240z/#findComment-639949 Share on other sites More sharing options...
May 3, 20222 yr Author comment_639950 Terrapin Z - please contact me at 978-505-1704. Yes I could use your help with this! TY Link to comment https://www.classiczcars.com/forums/topic/67448-half-shaft-flangeyoke-1970-240z/#findComment-639950 Share on other sites More sharing options...
