1975 to 1978 parts compatibility to interchange ?
Killain
Hay thank you, It's kinda hard to make out the parts name, I thought it was called Headlight access panel 82, but that is were it stops in description, and I'm not too sure I'm calling it the right part name ?
If you just look at the dates, you'll see that the early 280Z (1975 - May 1976) has a different part number than the late 280Z (after May 1976 - 1978). How much the "Protector-Front Fend" changed I don't know. But if you check the part numbers, they are the same for the "2 seater" and "2+2" models and for the same date span.
  • Who's Online   2 Members, 1 Anonymous, 722 Guests (See full list)
