June 18, 20222 yr Author comment_641634 Okay, the body harness has been stripped. I am very glad I didn’t try to use this thing. It’s melted / burnt in two places and has been messed with and rewrapped in three places. The next step is to compare this to the diagram and see what the story is. Link to comment https://www.classiczcars.com/forums/topic/67523-1973-240z-custom-wiring-from-scratch/?&page=2#findComment-641634 Share on other sites More sharing options...
June 19, 20222 yr Author comment_641650 I just learned something that is not immediately obvious to someone who has never done this kind of thing before: The positions and lengths of the lines in the wiring diagram DO NOT correspond to my harness very closely at all. Yes, the wires connecting one component to another are captured in the diagram, but there is no relationship between either the length or the proximity of one wire to another in that diagram to what is in the car. What I mean by this is the just because two wires are next to each other in the diagram does not mean they are in a same harness. The best example of this are the blue/white and blue/red wires that go from the antenna switch to the antenna. In the diagram these are very short and not near anything else. These two wires are the longest wires in my body harness, where they are twisted up with 18 other wires. There is also a random blue wire in the 1973 diagram coming from the Accessory Relay and going to nothing. It goes between the two flashers in the dash and just stops in the empty space. Just a word of caution to anyone else jumping into their first wiring project with both feet. They’re great for checking wire colors but you need a physical representation to refer to in order to make a new harness. Edited June 19, 20222 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/67523-1973-240z-custom-wiring-from-scratch/?&page=2#findComment-641650 Share on other sites More sharing options...
June 19, 20222 yr comment_641655 Yes, that is normally true of this type of wiring diagram Link to comment https://www.classiczcars.com/forums/topic/67523-1973-240z-custom-wiring-from-scratch/?&page=2#findComment-641655 Share on other sites More sharing options...
June 21, 20222 yr Author comment_641702 Okay, my plans suffered their first casualty: I will not be going with an electric compressor on my AC system. It’s possible, but I would need to have a 200 amp alternator to handle the draw. The one I have is 100 and can’t cover it. I would also have to figure out some kind of controller to make sure it was operating and cycling correctly, and I’m trying to avoid computers. The thing that really tipped it over the edge, though, is having to move it out of the engine bay to keep it cool. These things are too big and need pipes to the condenser, even if you move the condenser somewhere too, so there isn’t an obvious place to put it. So that simplifies my project a little. I can probably pull the trigger on my AC parts now. —- I think I want to have my additional interior components on a new / additional harness. I haven’t decided if it would attach to the body harness or the dash harness yet, but it is for my additional power supplies to charge phones and a Bluetooth speaker. At least two of them will be USB-C plugs, and the last either a 12-volt plug or another USB-C. Edited June 21, 20222 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/67523-1973-240z-custom-wiring-from-scratch/?&page=2#findComment-641702 Share on other sites More sharing options...
June 21, 20222 yr Author comment_641706 I have verified that is is the right harness for my car by the part number printed on the white shrink near the blue clip (24014-n3300). It isn't the one that came with the car, which I can tell because it has metallic green overspray on it and I am pretty sure my car never had. I think it is for a 7/72 to 7/73 car, which mine is (7/73), but it has the black connector sleeves for the defroster, which came on the 75-83 harnesses according to Banzai Motorworks. I still have two things I have not been able to figure out about this harness, though: 1. This one is minor. The room light wires should be Red w/ Blue, Black, and Black. I have 3 long wires that I know are for the room light based on the connectors on the ends, but they are Red w/ Blue, Black, and Red w/ Black. Is this maybe just a foible of my harness? I know these aren't mixed up with the defroster wires because I have accounted for those and verified them by the connectors on those wires, even though they are the same colors. This would not be the only place where the wire colors deviate from the diagram. The rear combination light connectors don't match the diagram either, but they do match the FSM. 2. This one is perplexing. I have two wires (White & White w/ Black stripe) coming out of the harness at the same point as the two wires that go to the left rear marker light. I haven't been able to find these in any of the wiring diagrams for any year. As far as I can tell, these do not go to the tail lights, license plate lights, fuel pump or sensor, antenna, or marker lights. Is this maybe a European, Canadian, Californian, or Right-Hand-Drive harness? Some of the diagrams specify market-specific options and others are USA only. They do have the same connectors as the Step Light wires on the other end of the harness, but that runs into the door from the front on the right side. The left door switch is on the dash harness, plus the connectors don't match, so it isn't that. Maybe rear fog lights (not in the diagram)? I'm pretty sure that these supply signal and power to the speaker that was in the left rear quarter panel. Any help figuring this out would be much appreciated! Edited June 23, 20222 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/67523-1973-240z-custom-wiring-from-scratch/?&page=2#findComment-641706 Share on other sites More sharing options...
June 25, 20222 yr Author comment_641791 I have a question about these plugs on the body harness: The one at the top of the photo is to the fuel pump and is labeled in the wiring diagram and the FSM. It has two wires (black, yellow) and two plugs in a T arrangement. The other on is the one I can’t identify. It has one plug and one wire (green) that is a heavier gauge than all of the other wires in the harness. The connector has a tooth for a clip and the wire goes all the way back to the blue 10-pin connector that joins the dashboard harness. I checked the FSM and don’t see a label for this wire where it describes that blue connector, but it is directly across from the yellow wire in that connector, which goes to the fuel pump. Is this just a third wire for that fuel pump harness? If so I wonder why they didn’t just use a 3-plug connector. Is it for the fuel tank sending unit? That is showing as two wires (black, yellow) in the diagram. Edited June 25, 20222 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/67523-1973-240z-custom-wiring-from-scratch/?&page=2#findComment-641791 Share on other sites More sharing options...
June 25, 20222 yr comment_641796 Yellow and black = Fuel sending unit. Green = fuel pump power. Link to comment https://www.classiczcars.com/forums/topic/67523-1973-240z-custom-wiring-from-scratch/?&page=2#findComment-641796 Share on other sites More sharing options...
June 26, 20222 yr Author comment_641806 4 hours ago, SteveJ said: Yellow and black = Fuel sending unit. Green = fuel pump power. Awesome! Thank you. I just realized I may have filed this thread in the wrong place. I don’t see an electrical section but maybe one of the moderators can move it to the right place. Edited June 26, 20222 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/67523-1973-240z-custom-wiring-from-scratch/?&page=2#findComment-641806 Share on other sites More sharing options...
June 26, 20222 yr Author comment_641825 Finished the inventory of the body harness… Tagged all the connectors and checked them against the diagram. Measured the lengths and identified all of the splice points. Here’s everything I’ll need to replicate it (except the optimal wire gauge), with the splice color indicating the color tape covering the splice: 1973 240z Body Harness Inventory Position Component Conector Color Connector Style Connector Image Direction # of Pins # of Wires Diagram Wire Color Harness Wire Color Min. Feet of Wire Needed 1 Instrument Harness A Blue 10-Prong F 10 10 White w/ Black White w/ Black [See Speaker] Blue w/ Red Blue w/ Red [See Antenna] White White [See Speaker] Blue w/ White Blue w/ White [See Antenna] Yellow Yellow [See Fuel Pump] Green w/ Black Green w/ Black [R. Comb. Lamp RH] Green w/ Red Green w/ Red [R. Comb. Lamp LH] Green Green [See Belt Switches] Green Green [See Seat Switch] Green Green (Heavy) [See Fuel Pump] 2 Instrument Harness B White 6-Prong M 6 6 Red w/ Black Red w/ Black (Thick) [See Rear Glass Defroster] Red w/ Blue Red w/ Blue [See Room Light] Yellow w/ Green Yellow w/ Green [See Hand Brake Switch] Green w/ White Green w/ White 18 (to Green Splice C) Red w/ Black Red w/ Black [R. Comb. Lamp LH] Black Black 1 (to Yellow Splice) 3 Door Switch Clear Spade F 2 2 Black Black [See Step Light Harness] Black Red w/ Black [See Room Light] 4 Step Light Harness Clear Bullet M 1 1 Black Black 2 Clear Bullet F 1 1 Red w/ Blue Red w/ Blue 1 4 Yellow Splice N/A N/A N/A N/A 2 2 Red w/ Blue Red w/ Blue N/A Black Black 5 Hand Brake Clear Spade F 1 1 Yellow w/ Green Yellow w/ Green 8 6 Green Splice A N/A N/A N/A N/A 3 3 Green Green N/A Green Green Green Green 7 Belt Switch RH White 3-Prong Mini F 3 2 Green w/ Black Green w/ Black [See Seat Switch] Green Green 7 7 Green Splice B N/A N/A N/A N/A 3 3 Green Green N/A Green w/ Black Green w/ Black 8 Seat Switch White 3-Prong Mini F 3 2 Green w/ Black Green w/ Black 1 Red Green 1 (from Green Splice A) 9 Belt Switch LH White 3-Prong Mini F 3 2 Green w/ Black Green w/ Black 1 (from Green Splice B) Green Green 12 9 White Splice A N/A N/A N/A N/A 2 2 Black Black N/A Black Black 10 Room Light Clear Spade F 1 1 Black Black 3 (from White Splice A) Clear Spade F 1 1 Red w/ Blue Red w/ Black 17 Black Spade M 1 1 – Red w/ Blue 17 11 Rear Glass Defroster Black Spade F 1 1 Black Black 19 Black Spade F 1 1 Red w/ Black Red w/ Black 15 12 Green Splice C N/A N/A N/A N/A 3 3 Green w/ White Green w/ White N/A Green w/ White Green w/ White 12 Rear Side Marker Light RH Clear Bullet M 1 1 Black Black 1 (from White Splice B ) Clear Bullet F 1 1 Green w/ White Green w/ White 1 (from Green Splice D) 13 Tank Sending Unit White 2-Prong w/ Clip F 2 2 Black Black 6 (from White Splice A) Yellow Yellow 14 Fuel Pump White 1-Prong F 1 1 Black Green 14 Yellow – – 14 Rear Combo Lamp RH White 4-prong Small F 4 4 Black Black 3 (to White Splice A) White w/ Black Green w/ Black 16 Green w/ White Green w/ White 2 (to Green Splice E) Red w/ Black Red w/ Black 1 (to Green Splice D) 14 Green Splice D N/A N/A N/A N/A 2 2 Red w/ Black Red w/ Black N/A Red w/ Black Red w/ Black 15 Green Splice E N/A N/A N/A N/A 3 3 Green w/ White Green w/ White N/A Green w/ White Green w/ White Green w/ White Green w/ White Green w/ White Green w/ White 15 License Plate Light Clear Bullet M 1 1 Black Black 2 (to White Splice B ) Clear Bullet F 1 1 Black Green w/ White 1 (from Green Splice E) 16 Rear Combo Lamp LH White 4-prong Small F 4 4 Black Black 1 (to White Splice B ) White w/ Black Green w/ Red 18 Green w/ White Green w/ White 1 (from Green Splice E) Red w/ Black Red w/ Black 18 16 White Splice B N/A N/A N/A N/A 2 2 Black Black N/A Black Black Black Black Black Black 17 Side Marker Light LH Clear Bullet M 1 1 Black Black 2 (from White Splice B ) Clear Bullet F 1 1 Green w/ White Green w/ Black 3 (from Green Splice E) 18 Speaker Clear Bullet M 1 1 – White w/ Black 19 Clear Bullet F 1 1 – White 19 19 Antenna Clear Bullet F 1 1 Blue w/ Red Blue w/ Red 20 Clear Bullet F 1 1 Blue w/ White Blue w/ White 20 Edited July 12, 20222 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/67523-1973-240z-custom-wiring-from-scratch/?&page=2#findComment-641825 Share on other sites More sharing options...
June 27, 20222 yr Author comment_641841 You may have noticed a few things I marked in Red in the last post. These were wires that differed from what I have in the Factory loom I disassembled in the wiring diagram. Well, I have a few more for the engine bay. I still have a lot of wire chasing and investigation to do, but I can point out two things: 1. The Throttle Opener Relay is missing from the wiring diagram I downloaded, but it is in the FSM wiring diagram for 1973 cars with manual transmissions (bottom left hand corner near the coil). 2. The 10-pin clips are differing pretty substantially this time. I am not surprised by a couple of wires being different colors, but also, the White and Black connectors are swapped from what is in the FSM and I am missing a wire in each of the other two. I need to find out somehow if these were removed or just never there in the first place. Maybe this will become apparent after I finish chasing the wires. Component Connector Color Connector Style Direction # of Pins # of Wires Diagram Wire Color Sample Wire Color Instrument Harness A Blue 10-Prong F 10 9 Red w/ Black Red w/ Black Red w/ White Red w/ White (Heavy) Green w/ Black Green w/ Black Green w/ Red Green w/ Red – – Yellow w/ Green Yellow w/ Green Red w/ Black Red w/ Black Black w/ Yellow – Red Red Blue w/ Yellow Blue w/ White Instrument Harness B Green 10-Prong F 10 8 Black Black Black Black (Heavy) Green w/ Black – – – – – Green w/ Black Green w/ Black Green w/ Red Green w/ Red Blue Black w/ Yellow Green Green Green Green Instrument Harness C White Black 10-Prong F 10 8 Yellow w/ Green Yellow w/ Green Blue Blue Black Black – – – – Red w/ Yellow Red w/ Yellow Red w/ Blue Red w/ Blue Green w/ Blue Green w/ Blue Red Red Blue w/ Yellow Blue w/ Yellow Instrument Harness D Black White 10-Prong F 10 9 Green w/ White Green w/ White Black w/ White Black White White Green Green – – Yellow w/ White Yellow w/ White Black w/ White Black w/ White Black w/ White Black w/ White Yellow w/ Blue Yellow w/ Black Yellow w/ Red Blue w/ Red Edited July 12, 20222 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/67523-1973-240z-custom-wiring-from-scratch/?&page=2#findComment-641841 Share on other sites More sharing options...
June 28, 20222 yr Author comment_641861 Well, I am pretty sure that my engine harness is for an automatic, not the manual harness I need. It has a 6-prong plug (G, B, B, BY, BY, BY) and a long branch with a yellow/blue wire. In the diagram that wire goes to the inhibitor. Both of these are automatic only. Not a crisis, because it was damaged and messed with in a number of places, but it does make using this as a guide to build my new one significantly harder. Edited June 29, 20222 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/67523-1973-240z-custom-wiring-from-scratch/?&page=2#findComment-641861 Share on other sites More sharing options...
June 29, 20222 yr Author comment_641883 Okay, I officially need help. I have 14 wires in this harness I cannot identify at all, and 5 that I think I have right but am not 100% sure about. Starting at where this harness connects to the dashboard harness, here is a list of what I have identified already: Instrument Harness A through D, To Dash Harness A from Alternator, To Dash Instrument Harness B from Starter Motor, Horn Relay, Intermittent Relay, and Hazard Wiper Motor Starter Motor, and Starter Ground Oil Pressure Switch, Alternator, and Alternator Ground Voltage Regulator and Condenser Inspection Light Side Marker Lamp RH, Parking & T/S & Side Front RH, Head Light RH, Fog Light RH, and Horn RH Horn LH, Fog Light LH, Parking & T/S & Side Front LH, Head Light LH, and Side Marker Lamp LH --- So, working from the end furthest from the firewall toward the dashboard connectors, this is what I am looking at: I have a yellow wire ending in a female bullet connector sharing a sleeve with a black wire ending in a female spade connector That black wire extends to where the yellow wire merges into the harness and has another female spade connector At that same point I have a green w/ white wire and a black w/ white wire, both ending in female spade connectors There is also a longer black w/ white wire ending in a female spade connector and shrouded in a black sleeve Further up the harness, about 10 inches from the bundle of wires for the lights on the left side of the car, I have 3 wires that have been cut: black w/ yellow, green, and black. See the far left side of the following image. The next mystery is a bundle of 4 wires that emerges between the bundle for the starter and the thick branch of wires that holds the wiper motor connector, among others. There are 2 red w/ black ending in male bullet connectors and 2 black w/ yellow ending in female bullet connectors. See the middle of the image below. (Also, can someone confirm that that is the water tank wire?) Lastly, I have two 4 wires emerging from that thick branch that holds the wiper motor connector and what I think is the seatbelt relay (automatic only). There is a black wire that is on its own and has been cut. There is also a bundle of 3 wires: black ending in a male spade connector, black w/ yellow ending in a female spade connector, and yellow with green ending in a female bullet connector. This bundle of wires is about 6 1/2 feet long, and the diagram does not show any yellow w/ green wires. (Can someone confirm that that is the seat belt relay connector?) --- So yeah. That's the hangup on finishing this step of the project. If anyone has any idea what these wires are for, please let me know. It is entirely possible that these were modifications the previous owner made, but I am hopeful that we can solve this collectively. Edited June 29, 20222 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/67523-1973-240z-custom-wiring-from-scratch/?&page=2#findComment-641883 Share on other sites More sharing options...
