Table Number 3!
This tableĀ represents half of the dashboard harness for a 1973 240z (PN 24013-M3321). It'sā€¦ okay. There are three items and a missing wire I can't identify (pink cells) and I am unsure about what I marked as the heater (bright yellow cells), but it's close. The other half will be in the next table.
Note: I'll post the wire lengths later.
1973 240z Dashboard Harness (24013-M3321) Inventory
Position Component Connector Color Connector Style Connector Image Direction # of Pins # of Wires Diagram Wire Color Sample Wire Color Min. Feet of Wire Needed
1
Body Harness
Blue
Nylon 10-Prong
Male
10
10
White w/ Black White w/ Black [See Speakers & Radio]
Blue w/ Red Blue w/ Red [See Power Antenna Switch]
White White [See Speakers & Radio]
Blue w/ White Blue w/ White [See Power Antenna Switch]
Yellow Yellow [See Ammeter & Fuel Gauge]
Green Green [See Electric Fuel Pump]
Green Green [See Engine Harness D]
Green Green [See Engine Harness B]
Green w/ Red Green w/ Red 4 (to Yellow Splice)
Green w/ Black Green w/ Black 4 (to Gray Splice F)
2
Engine Harness B
Green
Nylon 10-Prong
Male
10
7
Green Green 1
Green Green 4 (to Lt. Blue Splice D)
Black w/ Yellow Black w/ Yellow [See Ignition Switch]
Green w/ Red Green w/ Red 5 (to Lt. Blue Splice G)
Green w/ Black Green w/ Black 4 (to Gray Splice E)
Black ā€“ Ā
Black Black (Heavy) 1 (to Green Splice A)
Yellow w/ Red Yellow w/ Red [See Switch Element]
ā€“ ā€“ ā€“
ā€“ ā€“ ā€“
3
Engine Harness D
Black White
Nylon 10-Prong
Male
10
8
Blue w/ Red Blue w/ Red 2 (to Lt. Blue Splice B)
Yellow w/ Black Yellow w/ Black [See Water Temperature & Oil Temperature Gauge]
Black w/ White Black w/ White 4 (to Green Splice D)
Green Green 1
Yellow w/ White Yellow w/ White [See Water Temperature & Oil Temperature Gauge]
Green w/ White Green w/ White 4 (to Green Splice F)
Black w/ White Black w/ White [See Tachometer]
Green w/ White Green w/ White [See Hazard Switch]
Blue w/ White Blue w/ White 4 (to Gray Splice C)
ā€“ ā€“ ā€“
4 Engine Harness E White Nylon 3 Engine Harness E.JPG Male 1 1 White w/ Red White w/ Red (Heavy) 1 (to Gray Splice A)
5
Accessory Relay
White
Nylon
Ā
4
3
Blue Blue 4 (to Red Splice)
Blue Blue [See 30-Amp Fuse]
ā€“ ā€“ ā€“
Blue Blue [See Heater]
6
Rear Window Electric Defroster Relay
White
Nylon
Ā
4
4
White w/ Red White w/ Red (Thick) [See 20-Amp Fuse]
Blue w/ Red Blue w/ Red [See Rear Window Electric Defroster Switch]
Black Black 1 (to Green Splice A)
Red w/ Blue Red w/ Black (Thick) [See Junction 1A]
7 ? Clear Bullet 7 IMG_4941.JPG Female 1 1 Ā  Blue w/ Red 2 (to Lt. Blue Splice B)
8 Junction 1A Clear Bullet 8 Junction 1A.JPG Male 1 1 Red w/ Black (Thick) 1
Ā
Light Blue Splice A
N/A
N/A
N/A
N/A
2
Green
N/A
Green
Ā
Green Splice A
N/A
N/A
N/A
N/A
2
Black N/A
Black(Heavy) 2 (to Green Splice B)
Ā
Light Blue Splice B
N/A
N/A
N/A
N/A
2
Blue w/ Red
N/A
Blue w/ Red
Ā
Green Splice B
N/A
N/A
N/A
N/A
4
Black (Heavy) 4 (to Green Splice D)
Black
N/A
Black
Black
Ā
Light Blue Splice C
N/A
N/A
N/A
N/A
4
Green
N/A
Green
Yellow
Yellow w/ Red
Ā
Gray Splice A
N/A
N/A
N/A
N/A
2
N/A
White w/ Red
9 Junction 1B Clear Bullet 9 Junction 1B.JPG Female 1 1 Black 3
Ā
Light Blue Splice D
N/A
N/A
N/A
N/A
2
Green
N/A
Green
10
Speakers & Radio
White
Nylon
Male
3
3
White w/ Black White w/ Black 4
White White 4
Blue Blue 1 (from Red Splice)
11
White
Nylon
Female
3
3
Blue w/ Red Blue w/ Red 4
12 Heater Clear Bullet 12 Heater.JPG Female 1 1 Red Blue 4
13
Buzzer
White
Nylon
Female
3
3
Black
Black [See Door Switch LH]
Black 3 (to Green Splice C)
Green Green 2 (from Lt. Blue Splice D)
Ā
Green Splice C
N/A
N/A
N/A
N/A
2
Black
N/A
Black
14
30-Amp Fuse
White
Fuse
N/A
2
2
Blue Blue 4
Red Blue X (to Gray Splice B)
15
20-Amp Fuse
White
Fuse
N/A
2
2
White w/ Red White w/ Red 5
White w/ Red White w/ Red 3 (to Gray Splice B)
16
Choke Warning Light
White
Nylon
Male
3
2
Black Black 2 (from Green Splice C)
ā€“ ā€“ ā€“
Red w/ Blue Red w/ Blue [See Seatbelt Warning Light]
17
White
Nylon
Female
3
3
Blue w/ Red Blue w/ Red 5
Black Black 3 (from Green Splice C)
18
Electric Fuel Pump
White
Nylon T
Ā
2
2
Black Black w/ White 2 (to Green Splice D)
Green Green 5
19
White
Nylon
Ā
4
4
Red Red 2 (to Lt. Blue Splice E)
Green Green 3 (from Lt. Blue Splice D)
ā€“ Red w/ Blue 5
Ā
Red Splice
N/A
N/A
N/A
N/A
4
Blue
N/A
Blue
Blue
Blue
Ā
Gray Splice B
N/A
N/A
N/A
N/A
3
N/A
White w/ Red (Thi)ck
Blue
Ā
Light Blue Splice E
N/A
N/A
N/A
N/A
2
Red
N/A
Green
20
Fuse Box A
White
Nylon
Ā
6
6
Green w/ Yellow Green w/ Yellow 3 (to Gray Splice C)
Green w/ White Black w/ White (Thick) 4 (to Green Splice D)
Blue w/ Red Blue w/ Red [See Ignition Switch]
Blue Blue 1 (to Red Splice)
Blue w/ Red Blue w/ Red 3 (from Lt. Blue Splice B)
Green Green 2 (from Lt. Blue Splice E)
21 Fuse Box B Black Ring w/ Cap (Nylon in FSM) 21 Fuse Box B.JPG N/A 1 1 White w/ Red (Heavy) White w/ Red (Heavy) 3 (from Gray Splice B)
22 Fuse Box C Clear Bullet 22 Fuse Box C.JPG Male 1 1 Blue w/ White Blue w/ White [See Cigar Lighter]
Ā
Green Splice D
N/A
N/A
N/A
N/A
3
Black w/ White
N/A
Black w/ White
Black w/ White (Heavy) 3 (to Green Splice G)
Ā
Gray Splice C
N/A
N/A
N/A
N/A
2
Blue w/ White
N/A
Green w/ Yellow
23 Clock Clear Bullet 23 Clock.JPG Male 1 1 Black Black 1 (to Green Splice E)
24 Map Light Clear Bullet 24 Map Light.JPG Male 1 1 Black Black 3 (from Green Splice B)
25
White
Nylon
Female
4
3
ā€“ ā€“ ā€“
Yellow Yellow 4
Yellow w/ Red Yellow w/ Red 3 (from Lt. Blue Splice C)
26 Ammeter Black Ring w/ Cap (Nylon in FSM) 26 Ammeter.JPG N/A 1 1 White w/ Red (Heavy) White w/ Red (Heavy) 2 (from Gray Splice D)
Ā
Gray Splice D
N/A
N/A
N/A
N/A
3
White w/ Red (Heavy) 3 (from Gray Splice A)
N/A
Ā
Gray Splice E
N/A
N/A
N/A
N/A
3
Green w/ Black
N/A
Green w/ Black
Green w/ Black
Ā
Green Splice E
N/A
N/A
N/A
N/A
2
Black (Heavy)
N/A
Black
Ā
Light Blue Splice F
N/A
N/A
N/A
N/A
3
Green w/ Red
N/A
Green w/ Red
Green w/ Red
27
White
Nylon
Female
4
4
Yellow w/ Black Yellow w/ Black 4
Black Black 4 (from Green Splice E)
Yellow w/ White Yellow w/ White 4
Yellow Yellow X (from Lt. Blue Splice C)
Ā
Light Blue Splice G
N/A
N/A
N/A
N/A
3
Green
N/A
Green
Green w/ Yellow
28
Cigar Lighter
Black Spade
Male 1 1 Black Black 2 (to Green Splice G)
Clear Bullet Female 1 1 Blue w/ White Blue w/ White 4
29
Hazard Switch A
White
Nylon
Female
3
3
Green w/ Yellow Green w/ Yellow [See Brake Light Switch]
White w/ Black White w/ Black 2 (from Gray Splice F)
White w/ Red White w/ Red 1 (to Yellow Splice)
30
Hazard Switch B
White
Nylon
Female
6
6
Green Green 1 (from Lt. Blue Splice G)
Green Green [See Turn Signal Flasher Switch]
Green w/ Yellow Green w/ Yellow 3 (from Gray Splice C)
Green w/ Black Green w/ Black 2 (from Gray Splice E)
Green w/ Red Green w/ Red 3 (from Lt. Blue Splice F)
31 Hazard Switch C Clear Bullet 31 Hazard Switch C.JPG Female 1 1 Black Black 2 (to Green Splice G)
Ā
Gray Splice F
N/A
N/A
N/A
N/A
2
Green w/ Black
N/A
White w/ Black
Ā
Yellow Splice
N/A
N/A
N/A
N/A
2
Green w/ Red
N/A
White w/ Red
32
Tachometer
White
Nylon
Female
4
4
Black w/ White Black w/ White 5
Green w/ White Green w/ White 2 (to Green Splice F)
Green Green (Spliced to Red w/ Blue) 3 (from Lt. Blue Splice G)
33 Turn Signal Indicator Light LH Black Blulb
N/A 1 1 Green w/ Red Green w/ Red 2 (from Lt. Blue Splice F)
34 Turn Signal Indicator Light RH Black Blulb N/A 1 1 Green w/ Black Green w/ Black 2 (from Gray Splice E)
35
Switch Element
White
Nylon
Female
3
2
Yellow Yellow 2 (to Green Splice H)
ā€“ ā€“ ā€“
Yellow w/ Red Yellow w/ Red 5
Ā
Green Splice F
N/A
N/A
N/A
N/A
2
Green w/ White
N/A
Green w/ White
Ā
Green Splice G
N/A
N/A
N/A
N/A
4
Black (Heavy)
N/A
Black
Black
Black
Ā
Green Splice H
N/A
N/A
N/A
N/A
2
N/A
Yellow
36
Brake Indicator Light
Black
Bulb
N/A
2
2
ā€“ Green w/ Yellow 2 (from Lt. Blue Splice G)
Yellow w/ Blue Yellow w/ Green [See Hand Brake Junction]
37 Hand Brake Junction Clear Bullet Female 1 1 Yellow w/ Green 1
38 Door Switch LH Clear Bullet 38 Door Switch LH.JPG Female 1 1 Black Black 6
39
White
Nylon
Female
2
2
Green Green 6
White White [See Combination Switch B]
40
Brake Light Switch
Clear Bullet
Female 1 1 Green w/ Yellow Green w/ Yellow 6
Clear Bullet Female 1 1 Green w/ Yellow Green w/ Yellow [See Turn Signal Switch]
41
Turn Signal Switch
White
Nylon
Female
6
5
Green w/ Red Green w/ Red 2 (from Lt. Blue Splice G)
Green w/ Black Green w/ Black 3 (from Gray Splice E)
ā€“ ā€“ ā€“
Green w/ Black Green w/ Black 3 (from Gray Splice F)
Green w/ Red Green w/ Red 3 (from Yellow Splice)
Ā
Gray Splice G
N/A
N/A
N/A
N/A
3
White w/ Red (Heavy) 3 (from Gray Splice D)
N/A
42
Ignition Switch
White
Nylon
Female
6
5
ā€“ ā€“ ā€“
Blue w/ Red Blue w/ Red 6
White w/ Red White w/ Red (Double Thick) 2 (from Gray Splice G)
Black w/ Yellow Black w/ Yellow (Thick) 6
Black w/ White Black w/ White (Thick) 3 (from Green Splice H)
Green w/ White Green w/ White 3 (from Green Splice F)
43 Junction 1C Clear Bullet 43 Junction 1C.JPG Female 1 1 Blue w/ Red 6 (from Lt. Blue Splice B)
44 Combination Switch A Black Spade (Large)
Male 1 1 Black Black (Heavy) 2 (from Green Splice G)
45 Combination Switch B Black Spade Male 1 1 White White 6
46 Combination Switch C Clear Bullet Female 1 1 White w/ Red White w/ Red (Thick) 2 (from Gray Splice G)
Edited by Matthew Abate
15 hours ago, SteveJ said:
This may help you with identification
Oh man, this is so helpful! Thank you. I keep forgetting about the speakers.
I'll make these updates in my previous post.
The position of the blue with red stripe wire at position #7 is right out the big colored connectors. It is spliced to a blue / red wire that goes to the fuse box and another one of the same color for the junction connector that comes out at the ignition switch.
It has something to do with the wipers. The wiring diagram shows 3 blue w/ red wires: one going from the ignition switch to the fuse box, one out of the fuse box to the wiper motor, and one from the combination switch and connecting to a yellow / white wire that goes to the wiper fluid bottle.
So for #7, the LR wire coming off the fuse box goes in several directions.
  1. It turns into BY and goes out to the washer
  2. It goes to the Intermittent Relay for the wipers as LR
  3. It turns into R and goes out to the reverse switch (and inhibitor switch on the automatic).
There is another LR wire that goes from the defroster switch to the defroster relay.
I think there is a mistake on the wiring diagram for the intermittent relay. It shows the LR wire from the fuse box turning into BY when it gets to the intermittent relay, and another LR wire on the intermittent relay that goes to the wiper motor as BY. My guess is that BY and LR are swapped on the intermittent relay.
Can you post a photo of #7 with a little more context in the wire bundle? That may help narrow it down.
Here you go. It's the one in the black sheath with a female bullet connector pointing to the top of the photo (betweenĀ the blue wires and the white wire w/ the red stripe).
Ā
Perfect. Now I can look for it in my car.
Found it
Ā
Here are wires going to the intermittent relay:
Obviously, the wiring diagram in the FSM isn't quite right for the intermittent relay as it shows 9 wires. There isn't a BY wire going to the relay, and there is only one ground wire.
Ā
Amazing!
So not only does that solve #7 in harness #1, it solves for position #5 in harness #2, which you would not know because I have not posted the table for yet. The only mysteries I will have left are the 4 wires that are missing (2 from the dash and 2 from the engine) and a blue connector on this harness I am chasing now, which might be to the radio lights. Maybe I can find those using the diagrams.
Table Number 4!
This tableĀ represents the other half of the dashboard harness for a 1973 240z (PN 24013-M3322). It was much easier than the other half. There only two items I couldn't figure out: a missing wire in the blue 10-pin connector to the engine harnes and a blue wire near the fuse box branch what might be power to the Radio (pink cells).
Pretty close to done with this inventory now. I have some small harnesses to capture still (fuel pump harnesses and the heater controls harness), but I don't think I need them for my final build so I may do that later.
1973 240z Dashboard Harness (24013-M3322) Inventory
1
Engine Harness A
Blue
Nylon 10-Prong
Male
10
9
Blue w/ White Blue w/ White 1 (to Lt. Blue Splice D)
Red Red [See Fog Light Switch]
Black w/ Yellow ā€“ Ā
Red w/ Black Red w/ Black [See Body Harness Aux]
Yellow w/ Green Yellow w/ Green 1 (to Lt. Blue Splice A)
Red w/ Black Red w/ Black [See Light & Horn Switch]
Red w/ White Red w/ White (Thick) 5 (to Gray Splice)
Green w/ Black Green w/ Black [See Light & Horn Switch]
Green w/ Red Green w/ Red [See Fuse Box D]
ā€“ ā€“ ā€“
2
Engine Harness C
White Black
Nylon 10-Prong
Male
10
8
Red w/ Blue Red w/ Blue [See Combinations Switch E]
Red Red (Thick) 3 (to Brown Splice)
Green w/ Blue Green w/ Blue 1 (to White Splice A)
Red w/ Blue Red w/ Blue [See Fuse Box D]
Red w/ Yellow Red w/ Yellow (Thick) [See Fuse Box D]
Blue w/ Yellow Blue w/ Yellow [See Combinations Switch E]
Yellow w/ Black Yellow w/ Black [See Combinations Switch E]
Black Black 2 (to Lt. Blue Splice C)
ā€“ ā€“ ā€“
ā€“ ā€“ ā€“
3 Engine Harness F White Nylon 03 Engine Harness F.JPG Female 1 1 White White (Heavy) 2 (to Yellow Splice A)
4
Intermittent Relay
White
Nylon
Female
6
4
Blue w/ White Blue w/ White 2 (to Lt. Blue Splice C)
Blue Blue [See Combinations Switch E]
Blue w/ Red Blue w/ Red [See Intermittent Relay Junction 2]
Blue w/ White Blue w/ White 2 (to Lt. Blue Splice B)
ā€“ ā€“ ā€“
ā€“ ā€“ ā€“
5 Intermittent Relay Junction 2 Clear Bullet 05 Intermittent Relay Junction 2.JPG Male 1 1 Blue w/ Red 1
6
Body Harness Aux
White
Nylon
Female
6
6
Red w/ Black Red w/ Black 1
Red w/ Blue Red w/ Blue 3 (to Yellow Splice B)
Black Black 6 (to Yellow Splice F)
Red w/ Black Red w/ Black [See Junction 2A]
Green w/ White Green w/ White 2 (to White Splice A)
7 Junction 2A Clear Bullet 07 Junction 2A.JPG Male 1 1 Red w/ Black 1
Ā
Light Blue Splice A
N/A
N/A
N/A
N/A
2
Yellow w/ Green
N/A
Yellow w/ Green
Ā
White Splice A
N/A
N/A
N/A
N/A
2
Green w/ Blue N/A
Green w/ White 3 (to White Splice C)
Ā
Light Blue Splice B
N/A
N/A
N/A
N/A
2
Blue w/ White
N/A
Blue w/ White
Ā
Light Blue Splice C
N/A
N/A
N/A
N/A
2
Black
N/A
Blue w/ White
Ā
Brown Splice
N/A
N/A
N/A
N/A
2
Red (Thick)
N/A
Red
Ā
Yellow Splice A
N/A
N/A
N/A
N/A
2
White (Heavy)
N/A
White
Ā
Yellow Splice B
N/A
N/A
N/A
N/A
3
Red w/ Blue
N/A
Red w/ Blue
Red w/ Blue
Ā
White Splice B
N/A
N/A
N/A
N/A
2
Red w/ Blue
N/A
Green w/ White
8
Radio
White
Nylon
Female
3
2
Red w/ Blue Red w/ Blue 1 (from White Splice B)
Black Black [See Junction 2B]
9 Junction 2B Clear Bullet 09 Junction 2B.JPG Male 1 1 Black 1
10 Radio Illumination / Power - ? Clear Bullet 10 Radio Illumination : Power.JPG Female 1 1 Blue Blue 3 (to Yellow Splice D)
11
Fog Light Switch
White
Nylon "T"
Male
2
2
Red Red 4
Red w/ Green Green w/ White 2 (from White Splice B)
12
Fuse Box D
White
Nylon
Male
6
7
Red Red (Thick) 2 (from Brown Splice)
Red w/ Yellow Red w/ Yellow (Thick) 4
Green w/ Blue
Green w/ Blue [See Combinations Switch E]
Red w/ Blue 4
Red w/ Blue Red w/ Blue 2 (from Yellow Splice A)
Red Red (Thick) [See Combinations Switch D]
13 Fuse Box E Clear Bullet 13 Fuse Box E.JPG Female 1 1 White White (Thick) 3 (from Yellow Splice A)
14 Glove Box Light Clear Bullet 14 Glove Box Light.JPG Female 1 1 Red w/ Blue Red w/ Blue 1 (from Yellow Splice B)
15 Clock Power Clear Bullet 15 Clock Power.JPG Female 1 1 Blue Blue 1 (to Yellow Splice C)
16 Clock Illumination Black Bulb 16 Clock Illumination.JPG N/A 1 1 Red w/ Blue Red w/ Blue 2 (to Yellow Splice D)
17 Map Light Clear Bullet 17 Map Light.JPG Female 1 1 Red w/ Blue Red w/ Blue 1 (to Yellow Splice C)
Ā
White Splice C
N/A
N/A
N/A
N/A
3
Green w/ White 3 (to White Splice D)
18 Ammeter Black Ring w/ Cap (Nylon in FSM) 18 Ammeter.JPG N/A 1 1 White White (Heavy) 2 (from Yellow Splice A)
19 Ammeter & Fuel Gauge Illumination Black Bulb 19 Ammeter & Fuel Gauge Illumination.JPG N/A 1 1 Red w/ Blue Red w/ Blue 2 (to Yellow Splice D)
Ā
Yellow Splice C
N/A
N/A
N/A
N/A
3
Blue
N/A
Red w/ Blue
Red w/ Blue
20 Water Temperature & Oil Temperature Gauge Illumination Black Bulb 20 Water Temperature & Oil Temperature Gauge Illumination.JPG N/A 1 1 Red w/ Blue Red w/ Blue 1 (from Yellow Splice D)
Ā
Yellow Splice D
N/A
N/A
N/A
N/A
3
Blue
N/A
Red w/ Blue
Red w/ Blue
Red w/ Blue
21 Tachometer Illumination A Black Bulb 21 Tachometer Illumination A.JPG N/A 1 1 Red w/ Blue Red w/ Blue 2 (to Yellow Splice E)
22 Tachometer Illumination B Black Bulb 22 Tachometer Illumination B.JPG N/A 1 1 Red w/ Blue Red w/ Blue 2 (to Yellow Splice E)
23
Illumination Dimmer (Rheostat)
Black
Spade
Male
1
2
Red w/ Blue
Red w/ Blue 2 (from Yellow Splice D)
Clear Spade 23b Illumination Dimmer (Rheostat).JPG Female 1 1 Red w/ Blue Red w/ Blue 1 (to White Splice D)
24
Cigar & Hazard Fiber Optic Light Source
White
Nylon
Female
2
1
Ā  Red w/ Blue 1 (to White Splice D)
Ā  ā€“ ā€“
24b Cigar Lighter Junction.JPG Male 1 1 Ā  Black 1 (to Cigar Lighter)
Ā
Gray Splice
N/A
N/A
N/A
N/A
3
Ā
N/A
Ā
Ā
Ā
White Splice D
N/A
N/A
N/A
N/A
3
Red w/ Blue
N/A
Red w/ Blue
Green w/ White
25
Steering Lock Switch
Clear Spade
Male 1 1 Black Black 3 (from Yellow Splice F)
Clear Spade Female 1 1 Red Red [See Step Light Harness]
26
Light & Horn Switch
White
Nylon
Female
3
3
Red w/ White Red w/ White (Thick) 2 (from Gray Splice)
Red w/ Black Red w/ Black 6
Green w/ Black Green w/ Black 6
27 Combinations Switch D Clear Bullet 27 Combinations Switch D.JPG Male 1 1 Red Red (Thick) 6
28
White
Nylon
Female
9
9
Blue w/ Yellow Blue w/ Yellow 6
Blue Blue 7
Blue w/ Red Blue w/ Red [See Junction 2C]
Yellow w/ Black Yellow w/ Black 6
Red w/ Blue Red w/ Blue 6
Blue w/ White Blue w/ White 6 (from Lt. Blue Splice C)
Blue w/ White Blue w/ White 6 (from Lt. Blue Splice B)
Green w/ Blue Green w/ Blue 6
29 Junction 2C Clear Bullet 29 Junction 2C.JPG Male 1 1 Blue w/ Red 1
Ā
Yellow Splice E
N/A
N/A
N/A
N/A
3
Red w/ Blue
N/A
Red w/ Blue
Red w/ Blue
Ā
Yellow Splice F
N/A
N/A
N/A
N/A
2
Red w/ Blue
N/A
Red
Ā
Yellow Splice G
N/A
N/A
N/A
N/A
2
Black
N/A
Black
30 Speedometer Illumination Top Black Bulb 30 Speedometer Illumination  Top.JPG N/A 1 1 Red w/ Blue Red w/ Blue 1 (from Yellow Splice F)
31
High Beam Indicator Light
Black
Bulb
N/A
1
2
Red Red 4 (to Brown Splice)
Red w/ White Red w/ White 2 (from Gray Splice)
32 Speedometer Illumination Bottom Black Bulb 32 Speedometer Illumination  Bottom.JPG N/A 1 1 Red w/ Blue Red w/ Blue 2 (from Yellow Splice E)
33 Hand Brake Junction Clear Bullet 33 Hand Brake Junction.JPG Male 1 1 Yellow w/ Green 6 (from Lt. Blue Splice A)
34
Step Light Harness
Clear Bullet
Male 1 1 Black Black 1 (from Yellow Splice G)
Clear Bullet Female 1 1 Red w/ Blue Red w/ Blue 1 (from Yellow Splice F)
35
Door Switch LH
Clear Bullet
Female 1 1 Black Black 1 (from Yellow Splice G)
Clear Spade Female 1 1 Black Black 3
I did a quick tally of which wires need to be which gauge and this is what I ended up with:
Components Gauge Wire Color
Starter Ground, Combination Switch
10
Black
Ā  Black w/ White
Fuel Pump Green
Headlights Red w/ White
Starter, Ammeter White
Alternator, Ammeter White w/ Red
Ā
12
Black w/ White
Ignition Switch Black w/ Yellow
Ignition Switch Green w/ White
Headlights, Combination Switch Red
Rear Glass Defroster Red w/ Black
Light & Horn Switch Red w/ White
Headlights Red w/ Yellow
Fuse Box White
Ignition Switch, Combination Switch White w/ Red
All others would be 14 AWG. There may be some 16 or 18 AWG in the car originally, but I don't see a reason to go that light. Please let me know if you think I have any errors here. I'm also wondering if it would be worthwhile to step everything up one level, or if that would be a waste of money and weight.
Just be aware of what gauge wires your terminals are designed to take.Ā
Doing some quick resistance calculations, you are upsizing a lot of wires with little to no benefit. You may end up with an issue getting your engine harness through the hole in the firewall. (Keep in mind that it will probably be easier if you put the pins in the connectors after you get the harness through the firewall.)Ā
You may want to check out a voltage drop calculator like this:Ā https://www.calculator.net/voltage-drop-calculator.html
Choose estimated resistance. I did a quick calculation for the headlights with a swag for the distance and used incandescent sealed beam ratings. The voltage is 13.8 because that is toward the low end of operating voltage while the car is driving.
Many of your circuits for the engine harness are grounded close to the load, so this calculator would overestimate the voltage drop.Ā
The battery/charging system are your highest current circuits, so the larger gauge can easily be justified. No other circuit comes close especially if you change the parking light circuit to LEDs, as that is probably the biggest continuous draw you would see.
Other high draw circuits:
Fan (14 AWG is fine, but you might be better off with 12 AWG)
Fuel pump (This is about 10 A or less. 14 AWG would work.)
Headlights (depending upon whether or not you switch to LEDs. LEDs would drop this circuit to about 3 A.)
Edited by SteveJ
Fixing grammar
I plan to use LEDs but I want to wire the car so that I donā€™t HAVE to use LEDs, particularly forĀ the headlights.
My thoughts on having 14 AWG be my smallest wire was coming from a few things:
First, the amount of fried wiring I found. Itā€™s possible the heat came from outside but in places like under the dash I donā€™t know what would cause that, so I was assuming that it was overload on the wiring.
Second, the general use of 10-amp fuses for everything that wasnā€™t one of the fatter wires, plus the gauge charts Iā€™ve been using. However, I suspect the dash maybe could come down a notch for all the instruments and save me some headaches with fitting all that stuff in there.
Third, just eyeballing stuff looks like a lot of 14 AWG. Maybe Iā€™m off base and It's smaller than that. Tough to tell since it's actually Japanese (square millimeter?) wire and not AWG. need to go back over it more carefully.
I would love to plug all the numbers for everything in the car into a calculator, but I just donā€™t know where to find that information.
