Posted June 17, 20222 yr comment_641598 Okay, so today I re-turned the ignition lock key a little to quick, and suddenly nothing anymore. I know this problem is posted before here. Battery is good. But nothing is working. Where lies the problem ? Fuses are all OK. Amp meter ? I don't know how the 240z is wired exactly, since its been a long time I have been doing anything electrical on it. Gr Bart Link to comment https://www.classiczcars.com/forums/topic/67573-lost-all-power-ignition-240z/ Share on other sites More sharing options...
June 17, 20222 yr comment_641599 It might be the back side of the ignition switch that handles the electrical components. It is all plastic and wears out over the years. Easily replaced. Link to comment https://www.classiczcars.com/forums/topic/67573-lost-all-power-ignition-240z/#findComment-641599 Share on other sites More sharing options...
June 17, 20222 yr Author comment_641601 1 hour ago, jfa.series1 said: It might be the back side of the ignition switch that handles the electrical components. It is all plastic and wears out over the years. Easily replaced. That was my first thought to. I Will look into it tomorrow thanks Link to comment https://www.classiczcars.com/forums/topic/67573-lost-all-power-ignition-240z/#findComment-641601 Share on other sites More sharing options...
June 26, 20222 yr Author comment_641812 It's not the ignition switch. I did have some power back shortly. I do not hear a click anymore. Could it be this relay? Link to comment https://www.classiczcars.com/forums/topic/67573-lost-all-power-ignition-240z/#findComment-641812 Share on other sites More sharing options...
June 26, 20222 yr Author comment_641814 Fixed it! The problem was simply the battery terminals and to the block ( earth ). Not the terminal itself but the cable that is clamped to it ( Universal battery clamp ). Cleaned everything and some electro water resistant spray on it. Damn cold weather and moisture here 😭. Moisture is a big problem here even in summer... Link to comment https://www.classiczcars.com/forums/topic/67573-lost-all-power-ignition-240z/#findComment-641814 Share on other sites More sharing options...
June 27, 20222 yr comment_641832 Have you done also the Plus-pole connection? it looks like it's going to get the same problem.. Why all the tape? leave it off then you'll see the corrosion and you can spray the connection while doing a bit of maintenance! I bet you leave it.. untill one day .... the car stalls.. Link to comment https://www.classiczcars.com/forums/topic/67573-lost-all-power-ignition-240z/#findComment-641832 Share on other sites More sharing options...
June 28, 20222 yr Author comment_641859 On 6/27/2022 at 10:32 AM, dutchzcarguy said: Have you done also the Plus-pole connection? it looks like it's going to get the same problem.. Why all the tape? leave it off then you'll see the corrosion and you can spray the connection while doing a bit of maintenance! I bet you leave it.. untill one day .... the car stalls.. Yes I have done both Mart... It's not tape, it's vulancized rubber tape. It's pretty close to the metal battery hold down frame, I don't want anything exposed. Besides it helps with keeping the oxidation away. This lasted maybe 7 years or so, long enough till next time. lol why ? The battery clamp is still good, no need to replace it :P Link to comment https://www.classiczcars.com/forums/topic/67573-lost-all-power-ignition-240z/#findComment-641859 Share on other sites More sharing options...
June 28, 20222 yr Author comment_641860 On 6/17/2022 at 6:34 PM, jfa.series1 said: It might be the back side of the ignition switch that handles the electrical components. It is all plastic and wears out over the years. Easily replaced. Actually it was still good ! 50 plus years old, amazing japanese quality... kanto seiki so it's still original lock.. Link to comment https://www.classiczcars.com/forums/topic/67573-lost-all-power-ignition-240z/#findComment-641860 Share on other sites More sharing options...
