Posted July 2, 20222 yr comment_641982 Stock 280Z owners — how noisy is your fuel pump? Can you hear it spin up when you turn on the ignition? Constant running sound while driving? Annoying? Link to comment https://www.classiczcars.com/forums/topic/67604-280z-fuel-pump-noise/ Share on other sites More sharing options...
July 2, 20222 yr comment_641985 Mine isn't noisy but they are known to get that way or so I've read. Here's a good read that might be helpful. Some tips on quietening one down. https://atlanticz.ca/zclub/techtips/fuelpump/index.html Link to comment https://www.classiczcars.com/forums/topic/67604-280z-fuel-pump-noise/#findComment-641985 Share on other sites More sharing options...
July 2, 20222 yr comment_641989 mine makes a whizzing noise with the starter disabled. Link to comment https://www.classiczcars.com/forums/topic/67604-280z-fuel-pump-noise/#findComment-641989 Share on other sites More sharing options...
July 2, 20222 yr comment_641992 Pretty common for people to hear the aftermarket pumps. Mounting them loosely in rubber makes the difference. Some people hear the Walbro 255 pump even when it's mounted well. It pumps way more volume than the system needs and will make noise due to the strain of pumping through small lines. Link to comment https://www.classiczcars.com/forums/topic/67604-280z-fuel-pump-noise/#findComment-641992 Share on other sites More sharing options...
July 2, 20222 yr comment_641994 On 7/2/2022 at 5:18 PM, JayZ12 said: Constant running sound while driving? Annoying? Oh yeah, I have a 6to1 header with 2.5" exhaust. Could be why I never hear mine. Link to comment https://www.classiczcars.com/forums/topic/67604-280z-fuel-pump-noise/#findComment-641994 Share on other sites More sharing options...
July 2, 20222 yr Author comment_641995 On 7/2/2022 at 6:20 PM, siteunseen said: Mine isn't noisy but they are known to get that way or so I've read. Here's a good read that might be helpful. Some tips on quietening one down. https://atlanticz.ca/zclub/techtips/fuelpump/index.html Excellent read and very helpful. Thanks! I’m going to replace the pump with a new one and implement these cushioning suggestions. Link to comment https://www.classiczcars.com/forums/topic/67604-280z-fuel-pump-noise/#findComment-641995 Share on other sites More sharing options...
August 2, 20222 yr Author comment_643216 Must report I just completed this project of replacing my fuel pump with a new original stock one, with increased noise/vibration dampening, and the results are amazing! The new pump is virtually silent. Thanks again for the tips. Winning! Link to comment https://www.classiczcars.com/forums/topic/67604-280z-fuel-pump-noise/#findComment-643216 Share on other sites More sharing options...
