Posted July 19, 20222 yr comment_642650 Does anyone happen to know the thread size on the gear shift lever for the gear shift knob? Link to comment https://www.classiczcars.com/forums/topic/67661-manual-transmission-1974-260z/ Share on other sites More sharing options...
July 19, 20222 yr comment_642655 I'm pretty sure it's M8x1.25. About 8 years ago I bought a new shift knob for my 260Z, and it wasn't the right size thread. I took out the M10 insert and swapped in one of these threaded inserts. https://www.amazon.com/gp/product/B002QUZNUO It was a lot cheaper back then, too. Link to comment https://www.classiczcars.com/forums/topic/67661-manual-transmission-1974-260z/#findComment-642655 Share on other sites More sharing options...
July 19, 20222 yr Author comment_642661 I'm not sure that's correct. The one I ordered came with an 8mm brass insert and it's too small. Could it vary by manufacture date or something? Link to comment https://www.classiczcars.com/forums/topic/67661-manual-transmission-1974-260z/#findComment-642661 Share on other sites More sharing options...
July 19, 20222 yr Author comment_642664 You were right. I got out my tap and die set and sure enough it's 8 x 1.25. The top of the thread was damaged so I had to retap it. Thanks. Link to comment https://www.classiczcars.com/forums/topic/67661-manual-transmission-1974-260z/#findComment-642664 Share on other sites More sharing options...
