XTD clutch bolt alignment
MM569457
Good evening,
trying to install this XTD clutch. 6 of 9 bolts line up.  Is this normal for after market pressure plates or is this a part that needs all 9 bolts.
I’ve tried researching the part number and haven’t found anything relating to it or if it is for Datsun Zs.
225mm Z clutches use 6 bolts, 240mm clutches use 9. What is the diameter of the friction surface on that flywheel? Is it stock?
Can’t say I’ve ever tried to put a 225mm pressure plate on a 240mm flywheel to see what bolts line up.   Should go do that
Edited by zKars
  • Agree 1
