76 280Z Rust Issue
bhermes
I am in the process of selling my 76 280Z 2+2.  Recently I had a brake line leak that was fixed but I believe caused a rust issue.  I am attaching a photo of the concerned area.  For reference it is about the size of a baseball.  I have seen some replacement pieces for sale, I think that are welded on, for a fix.  However, it appears to me that these pieces are more cosmetic than structural.
I do have access to a good welder so welding is an option.
Thoughts/Comments/Suggestions.
You can give patching a try.  But, rust is a little like icebergs in that often you only see the tip of it and a lot more is hidden.  Poke around and see how solid the surrounding metal feels.  You may end up replacing a whole panel if you plan on keeping the car for years.
Is that the left frame rail, under the driver’s side footwell?
I see rust on the floor pan too. Looks like your Z needs frame rails and floor pans.
Any “patch job” will only be a band aid, and the problem will be passed on to the next owner.
Edited by Racer X
  • Agree 2
This is the passenger side I believe caused by a brake line leak.
When you say needs "frame rails and floor pans".  Is that something that can be purchased?  I saw some sheet metal ones for sale but kind of feel this is cosmetic not structural.
I am getting a lot of interest from my listing but feel it is going to be difficult to sale with the rust issue.
Thanks.
Thanks.
A brake line leak didn’t cause that.
Yes, the sheet metal is available. There is a company in Florida that is producing an ever growing assortment of pieces for Z cars, including frame rails and floor pans. Oh, and the rust pictured is definitely structural, not cosmetic.
And the rust would concern me if I was considering buying this car.
