Parts for Sale: 240Z Parts Collection - FREE
Posted
240Z parts collection:
FREE to good 240Z home.
Conditions of transfer:
          First committed pickup gets it all.
          You Come and Get It All.
          You take it ALL (including 240Z 2.4L engine long block).
There is more stuff than actually listed.
Transmission and Differential mounts
2 Drive shafts (diff lengths)
VG Hood Latch Mechanism
Throttle mechanism rubber boot
VG Fuel pressure regulator w/gauge
(2) Shift Levers (Different shapes
Speedo cable
VG Transmission Cross Member w/new poly bushings
VG battery tray
Windshield Wiper Motor
L/R Windshield Washer Nozzles
E-brake cable
Different speedo gears
Repaired Original Windshield Washer tank
Passenger door glass
NEW windshield gasket -
Stainless Windshield trim surround
L/R Stainless Roof over door gutter trim
 (3) Rear Hatch Struts (all w/good extension tension)
One set of side marker (1-yellow/1-red) lights
Original front calipers and rotors
Larger Toyota calipers (for stock rotors)
NEW Wilwood Brake Rotors
One cast iron rear brake drum
Set of 4 NEW 280Z rear brake shoes
L/R Front disk dust shields
(2) Tokiko strut inserts (used) -
Steering rack and pinion -
Rear Suspension - Front Cross member
Right Front lower suspension arm w/ball joint and tension bar
Batch of many Sway Bar Bushings and End Links and bushings
Box of metric 240Z-ish nuts, bolts, screws, misc small parts.
Front grill (dis-assembled)
Misc black carpeting and vinyl Trim -
Various Console lights & Switch wiring, Cig Lighter
Rear Parcel Tie down Straps (3 strap w/buckle sets, 1 strap no buckle)
Lower seat vinyl
Drivers Door Arm Rest
Gas Pedal rubber cover
A/C housings, condenser
1973 Datsun 240Z 2.4L long block - 89k original miles
Mild Cal Cams street cam for 240Z E88 head  -
Original Front Harmonic Dampener
(2) Starters
“Twice Pipes” Exhaust system
Various Distributors models (Points and Trans Ign) -
Accel Super Stack coil #8140 -
New water pump
Fan Clutch
2-piece fan shroud
Speedo cable -
(2) Alternators -
Posted
Sounds like when I moved from MI to AZ last year.  I had only a few weeks to get rid of 40 years of Z part hoarding.  I basically gave away truckloads of stuff.  What people didn't get before I left went into a dumpster.  I looked at it as paying it forward.  Hopefully, many of the parts will find their way onto other cars.  The OP in this thread sounds like he or she is in a similar situation.
