Posted August 11, 20222 yr comment_643755 Started my '71 240z this morning for a drive. While idling noticed the oil pressure gauge was sitting on zero. Shut it down, checked oil level (good). Started again and removed the oil filler cap, looks like lots of oil being slung around. Maybe the sender has failed, maybe the wiring, maybe the gauge. What's the next troubleshooting step? Link to comment https://www.classiczcars.com/forums/topic/67740-oil-pressure-gauge-says-no-oil-pressure/ Share on other sites More sharing options...
August 11, 20222 yr comment_643757 Remove the wire from the oil pressure sender and short the wire to the chassis. The best way to do this is have a wire with an alligator clip on one end and a normal male bullet connector on the other end. Clip the wire to the shock tower or negative terminal of the battery and connect the bullet to the wire for the oil pressure sender. Go in your car. Put the key in ON (don't start the car) and watch the oil pressure gauge. If it shoots up, you probably have a bad sender. Definitive diagnosis would be to confirm with a mechanical gauge. See this thread for info on installing a mechanical gauge: Link to comment https://www.classiczcars.com/forums/topic/67740-oil-pressure-gauge-says-no-oil-pressure/#findComment-643757 Share on other sites More sharing options...
August 19, 20222 yr Author comment_644193 So the Glow Shift adapter, which goes between the block and the sender, arrived today. Stupid Q: do I need to drain the engine oil before removing the existing sender, or is the sender above the oil level in the block? Link to comment https://www.classiczcars.com/forums/topic/67740-oil-pressure-gauge-says-no-oil-pressure/#findComment-644193 Share on other sites More sharing options...
August 19, 20222 yr comment_644197 no need to drain the oil. sender is above the level. Link to comment https://www.classiczcars.com/forums/topic/67740-oil-pressure-gauge-says-no-oil-pressure/#findComment-644197 Share on other sites More sharing options...
August 19, 20222 yr comment_644199 On 8/19/2022 at 2:16 AM, kenward1000 said: So the Glow Shift adapter, which goes between the block and the sender, arrived today. Stupid Q: do I need to drain the engine oil before removing the existing sender, or is the sender above the oil level in the block? Also, don't use teflon tape on the threads. If you do, you'll likely insulate the stock sender from the block. Link to comment https://www.classiczcars.com/forums/topic/67740-oil-pressure-gauge-says-no-oil-pressure/#findComment-644199 Share on other sites More sharing options...
August 19, 20222 yr comment_644209 On 8/19/2022 at 2:16 AM, kenward1000 said: So the Glow Shift adapter, which goes between the block and the sender, arrived today. Stupid Q: do I need to drain the engine oil before removing the existing sender, or is the sender above the oil level in the block? As mentioned, the oil pressure port is above the resting oil level in the crankcase. Note where the dipstick is, and the oil level on it when checked, in relation to the location of the oil pressure port. Just don’t try to do it with the engine running. Link to comment https://www.classiczcars.com/forums/topic/67740-oil-pressure-gauge-says-no-oil-pressure/#findComment-644209 Share on other sites More sharing options...
August 20, 20222 yr comment_644244 You will see some leakage from the oil galley but it should be limited Link to comment https://www.classiczcars.com/forums/topic/67740-oil-pressure-gauge-says-no-oil-pressure/#findComment-644244 Share on other sites More sharing options...
