Posted August 14, 20222 yr comment_643937 I’m trying to track down an electrical issue and I’m going through the fsm and I found the wire I’m looking for, but it goes through the connector c-1. The issue is that on the last page, it shows the connector with the same shape that I saw on the diagram, but it has an arrow pointing to a different shaped connector. Does anyone know what this means? Image is attached. Link to comment https://www.classiczcars.com/forums/topic/67752-factory-service-manual-question/ Share on other sites More sharing options...
August 14, 20222 yr comment_643939 Can you tell us the year FSM? Link to comment https://www.classiczcars.com/forums/topic/67752-factory-service-manual-question/#findComment-643939 Share on other sites More sharing options...
August 14, 20222 yr Author comment_643940 77 Link to comment https://www.classiczcars.com/forums/topic/67752-factory-service-manual-question/#findComment-643940 Share on other sites More sharing options...
August 15, 20222 yr comment_643941 In my understanding of these diagrams, the upper C1 shows the x'ed out ones have no wires in this positions. The lower C1 is what the plug actually looks like. SteveJ will know for sure about this. 🙂 Link to comment https://www.classiczcars.com/forums/topic/67752-factory-service-manual-question/#findComment-643941 Share on other sites More sharing options...
August 15, 20222 yr Author comment_643942 That would make sense because it has the same number of pins, or spaces for pins. Link to comment https://www.classiczcars.com/forums/topic/67752-factory-service-manual-question/#findComment-643942 Share on other sites More sharing options...
August 15, 20222 yr comment_643943 @Terrapin Zis correct. Those connectors are also color coded. C1 is blue as indicated on the wiring diagram. Another convention, knowing which side has the male pins: So in the wiring diagram: The male pins should be on the engine harness side, and the female pins should be on the body harness. If you see how the connector is shown in the wiring diagram, there are no wires going to where the Xs are. Link to comment https://www.classiczcars.com/forums/topic/67752-factory-service-manual-question/#findComment-643943 Share on other sites More sharing options...
August 15, 20222 yr Author comment_643944 @SteveJÂ Thank you. That makes a lot more sense now. Link to comment https://www.classiczcars.com/forums/topic/67752-factory-service-manual-question/#findComment-643944 Share on other sites More sharing options...
