Posted June 24, 200321 yr comment_41933 i took my car in to the shop to get it to pass smog, and they said they couldnt do it because they couldnt adjust the timing. supposedly the pulley had "slipped" on the harmonic balancer, so the groove doesnt line up where its supposed to. and they wanted to charge me $220 for a new harmonic balancer!!! ive never even heard of a pulley slipping, but i thought to myself, why cant i just get the engine to TDC, and then just take white out and draw a line where the mark is supposed to be, so i dont have to pay 200 bux for a new pulley?? the only problem is, how can i get the engine to TDC without the timing mark. can anyone provide some insight into this? what do i want my timing to be set at to get the car to pass smog? its a california 78 280z. thnks guys!! Link to comment https://www.classiczcars.com/forums/topic/6776-adjust-timing/ Share on other sites More sharing options...
June 25, 200321 yr comment_41946 To get the engine to tdc . This is the easyest , pull the pluggs then fit a socket on the front pully and turn the engine over with a ratichit while your finger is over the spark plug hole and when the piston comes up to the top you will feel the compression, shine a light in the hole and y ou will see the top of the piston come up and when it stops , as you are turning the crank you are at TDC. As far as what to set the engine to pass emissions I cant help you there. I would guess some where around 8 d BTC While you have the plugs out clean them and use a little anti-seze on the threads. Keeps them from gahling on the aluminum head. Especially when you remove them and the engine is warmed up. :classic: Link to comment https://www.classiczcars.com/forums/topic/6776-adjust-timing/#findComment-41946 Share on other sites More sharing options...
June 25, 200321 yr Author comment_41993 i want it to be as accurate as possible though, is there a way to do it if i pulled the valve cover that would be more accurate? Link to comment https://www.classiczcars.com/forums/topic/6776-adjust-timing/#findComment-41993 Share on other sites More sharing options...
June 25, 200321 yr comment_41999 Originally posted by beandip turn the engine over with a ratichit while your finger is over the spark plug hole and when the piston comes up to the top you will feel the compression, shine a light in the hole and y ou will see the top of the piston come up and when it stops , as you are turning the crank you are at TDC.Originally posted by xkeithx i want it to be as accurate as possible though, is there a way to do it if i pulled the valve cover that would be more accurate? How much more accurate do you want than actually SEEING the piston reach the top of it's stroke? Link to comment https://www.classiczcars.com/forums/topic/6776-adjust-timing/#findComment-41999 Share on other sites More sharing options...
June 25, 200321 yr comment_42004 Put out aill sparks for easier turning of the engine. Put into the hole of #1 a stiff wire with a soft coat (about 7 inch long) that has a little weight (soft material) at the one end that you put into that #1 hole. The stick acts like a needle in your speedometer. The longer outer end goes down when cylinder #1 is rising and it goes up when the cylinder goes down. At the lowest point you have TDC. Take care nothing will remain inside when you take the wire out. Good luck.Rolf Link to comment https://www.classiczcars.com/forums/topic/6776-adjust-timing/#findComment-42004 Share on other sites More sharing options...
June 25, 200321 yr comment_42028 What do you use to clean the spark plugs? I need to do mine. Link to comment https://www.classiczcars.com/forums/topic/6776-adjust-timing/#findComment-42028 Share on other sites More sharing options...
June 26, 200321 yr comment_42168 What, no replies?I'm sure that this is a stupid question but I just would not want to use the wrong thing and mess something up.The weekend is approaching and I would like to buy the stuff beforehand. Link to comment https://www.classiczcars.com/forums/topic/6776-adjust-timing/#findComment-42168 Share on other sites More sharing options...
June 26, 200321 yr comment_42172 I generally use a new set of plugs. cleans them up perfectly Link to comment https://www.classiczcars.com/forums/topic/6776-adjust-timing/#findComment-42172 Share on other sites More sharing options...
June 26, 200321 yr comment_42173 Originally posted by Victor Laury I generally use a new set of plugs. cleans them up perfectly I agree with Victor. Cost for a new set of NGK BP-6 plugs is about $10.00 Why muck around cleaning old ones? New plugs, new cap and rotor (points too, if you still haven't gone to Pertronix), set the timing and you should be good to go in a hour or two.Some things take more time and effort than it is worth bothering with. Link to comment https://www.classiczcars.com/forums/topic/6776-adjust-timing/#findComment-42173 Share on other sites More sharing options...
June 26, 200321 yr comment_42194 Well, I have some blow by and I'm sure that it's fowling plugs and instead of replacing the constantly I was thinking that I could just clean them up every couple weeks or so. I will not be driving the car much, probably once a week or so. Then when this problem is fixed I would replace the plugs. This is what I was thinking any how, maybe this is a bad route to go. I don't know. Link to comment https://www.classiczcars.com/forums/topic/6776-adjust-timing/#findComment-42194 Share on other sites More sharing options...
June 26, 200321 yr comment_42199 Originally posted by texasz Well, I have some blow by and I'm sure that it's fowling plugs Blow-by? Do you mean blow-by as in the piston rings aren't seating to the cylinder walls and the combustion pressure is blowing-by (past) the rings into the crankcase? If so, I guess I'm not sure how that would foul the plugs. Of course, I'm NOT an engine expert. Have you checked your compression? What are the readings?Have you done a leakdown test? What color are the plugs? How long does it take them to get that color? Link to comment https://www.classiczcars.com/forums/topic/6776-adjust-timing/#findComment-42199 Share on other sites More sharing options...
June 27, 200321 yr comment_42213 Whoa, whoa, whoa....let me catch up with you... :cross-eye I have not pulled them yet, I will this weekend. I had someone come out and look at the car Tues. night and he helped me get it more in tune so now it idles without stalling. He told me that I have some blow-by and that it's probably a ring that's not seated properly. What's going on is the hose that comes off the valve cover empties into the air filter. There is some oil that has accumulated in there and due to how this is angled it messes with the rear carb. With this hose pulled off the car runs MUCH better, however then the oil just lands on other parts of the car (I'm going to get a valve cover breather, one of those little filters to help this). It doesn't seem to be real bad but I won't be out racing the car like this or anything. I have not checked compression, I will do that this weekend also. I do not have the a leak down tester, I have a compressor just not the tester so I can not do this test. I wish I could because I would really like to do one. The guy that was helping me is a mobile mechanic that my family has used for many years. He said that it is likely that the plugs are fouled due to the blow-by. This may have also been an idea that he thought about while we were test driving it as it did seem to miss on hard acceleration sometimes. Whew!! I think that I cover it all...for now at least. Link to comment https://www.classiczcars.com/forums/topic/6776-adjust-timing/#findComment-42213 Share on other sites More sharing options...
