Posted August 21, 20222 yr comment_644317 Good morning, I’ve been trying to mate my 5 speed transmission onto the engine. This should be pretty straightforward. I used the clutch alignment tool when lining up the clutch to the flywheel and removed it after tightening down the pressure plate. But the transmission still not go all the way in. The input shaft seems to get hung up. How can I rectify this? Any ideas would be appreciated. Link to comment https://www.classiczcars.com/forums/topic/67773-mating-engine-to-transmission/ Share on other sites More sharing options...
August 21, 20222 yr comment_644318 I'd first verify the input shaft fits the bearing Link to comment https://www.classiczcars.com/forums/topic/67773-mating-engine-to-transmission/#findComment-644318 Share on other sites More sharing options...
August 21, 20222 yr Author comment_644319 3 minutes ago, Mark Maras said: I'd first verify the input shaft fits the bearing It does. New pilot bearing was same size as the old oneZ Link to comment https://www.classiczcars.com/forums/topic/67773-mating-engine-to-transmission/#findComment-644319 Share on other sites More sharing options...
August 21, 20222 yr comment_644321 46 minutes ago, MM569457 said: all the way in How far does it go? How big is the gap? Link to comment https://www.classiczcars.com/forums/topic/67773-mating-engine-to-transmission/#findComment-644321 Share on other sites More sharing options...
August 21, 20222 yr Author comment_644322 Maybe 3/4 of an inch. Link to comment https://www.classiczcars.com/forums/topic/67773-mating-engine-to-transmission/#findComment-644322 Share on other sites More sharing options...
August 21, 20222 yr comment_644325 I've run into this problem in the past. The clutch alignment tool I used was a bit sloppy. and allowed the clutch disc to drop down a bit before I tightened it. Trans wouldn't go in that last little bit. I loosened the pressure plate just enough to be able to move the disc into the truly centered position, tightened it down and the trans slid right in. Link to comment https://www.classiczcars.com/forums/topic/67773-mating-engine-to-transmission/#findComment-644325 Share on other sites More sharing options...
August 21, 20222 yr comment_644326 I can second the instance where the clutch alignment tool supplied let the disc slip. I nearly beat the hell out of my engine and transmission before I figured it out haha. It was the tool that came with the Excedy kit currently installed on the car. Link to comment https://www.classiczcars.com/forums/topic/67773-mating-engine-to-transmission/#findComment-644326 Share on other sites More sharing options...
August 22, 20222 yr comment_644356 When you get the tranny square to the block 1 to 2 inches opening equally all around, thread a long head bolt through two of the holes for the 4 tranny bolt holes and thread into the block. Then you know that you are aligned and it will slide right in. I believe if I remember correctly, you only have room to thread 2 in. This will guide your tranny right in……I’ve personally never had problem with the clutch alignment tool…..it’s always been a frickin PITA to man handle the engine without making sure everything is lined up squarely. This assures that it is! Edited August 22, 20222 yr by Diseazd Link to comment https://www.classiczcars.com/forums/topic/67773-mating-engine-to-transmission/#findComment-644356 Share on other sites More sharing options...
August 22, 20222 yr comment_644359 The alignment tool hangs on the spigot bearing and can actually mis-alignment. Insert the tool again and check the pressure plate finger around the tool are equally speced. Pay special attention directly above and under the tool are equal. If not equal, loosen the pressure plate and adjust accordingly. I wouldn't force it in. You can gently pull it in using threaded bar, but be gentle. You can scrape a thin layer off the inner side of the spigot bearing. That can cause unbalance. Link to comment https://www.classiczcars.com/forums/topic/67773-mating-engine-to-transmission/#findComment-644359 Share on other sites More sharing options...
August 22, 20222 yr comment_644360 People have just eyeballed the disc over the spigot/pilot bushing to get it centered with good luck.. I'm pretty sure that you can get it centered also by eyeballing the edges of the disc on the flywheel. Just make the edges even all the way around. Sometimes, you can just wiggle the transmission around and/or lift it up and down a bit to get the shaft started. The input shaft actually has some play in it so even though the transmission body might be aligned the shaft itself can be a bit low. Your input shaft has a pretty big chamfer cut in to it so should actually be easy to start. Put a small amount of grease on the tip it, it might help. But, I've had a pilot bushing that was just wrong-sized. It wouldn't fit in the crankshaft. I had to break it in to pieces to get it back out after getting it halfway in. So sizing errors are possible. Might be worthwhile to spend a few bucks and get another of the same brand just to be sure it fits the input shaft. Then maybe replace what's in there with the known quantity. Edited August 22, 20222 yr by Zed Head + in Link to comment https://www.classiczcars.com/forums/topic/67773-mating-engine-to-transmission/#findComment-644360 Share on other sites More sharing options...
August 22, 20222 yr comment_644361 I installed a could long guide bolts with the heads cut off (and sloted for later removal) that I could slip the trans over taking the weight and guiding it in. Still a bit of a battle sometimes its a skirmish sometimes its a war but it will just all of a sudden pop in. I try to avg the slop in the install tool, as it tends to droop under the weight of the clutch disk. repeatedly check for easy insertion of the tool while tightening up the pressure plate and see if it seems centered (again the droop of a plastic tool and some clearance needed to make it work). make sure dowels are in good shape (maybe thats been covered). biggest advice is to NEVER use the bolts to pull it together. Edited August 22, 20222 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/67773-mating-engine-to-transmission/#findComment-644361 Share on other sites More sharing options...
August 22, 20222 yr comment_644362 Used up head bolts work perfectly. Just cut the heads off and put a slot in them. Done this several times. Good luck. Happy wrenching. Cheers, Mike Link to comment https://www.classiczcars.com/forums/topic/67773-mating-engine-to-transmission/#findComment-644362 Share on other sites More sharing options...
