Hey all, the previous owner left me without an air filter. I just cleaned the carbs and working on building out the rest of the intake. What filtering system would you recommend? Common ones I'm seeing are:
image.pngRamflo Air Cleaner
image.pngITG Single Air Cleaner
image.pngITG Dual Air Cleaner
image.pngK&N Air Cleaner
image.pngK&N Carburetor Air Filter Set
image.pngUNI Air Filter Set
image.png Stock Air Filter
Edited by nkopp
https://www.classiczcars.com/forums/topic/67808-help-picking-an-air-filter/
I like the original. You have all the hose connections already there. They are a little tricky getting the cover and filter in place but once you get the carbs adjusted right you won't need to remove anything for a long time. The filters are still available from Nissan too.
https://www.courtesyparts.com/oem-parts/nissan-air-filter-16546e3210
The stock air filter housing checks all the boxes:
- Cold air supply to both carbs, well protected from the exhaust manifold heat
- Fittings for the carb overflow hoses and crankcase vent hoses
- Air horns to smooth the air flow into the carbs
- Efficient filter specifically designed for the carbs
I did the ITG dual and have air horns inside. Float bowl vents and valve cover vent attached similarly to the original but I did have to drill the back plate for the vent fittings.
According to the ZTherapy VHS tape, someone did independent flow testing of a number of intake/air horn combinations, and the stock air horns flowed the best.  Nissan got it right the first time, looks like.
