Rear tail light panels
gotham22
I know this has been covered many times.  However, I thought I would post to help others.  I repainted my tail light rear panels this weekend - 1978 280z.  I am very happy with the outcome.  I know this may not suffice for the purists.  I did an awful sanding job and I will have to go back and re-do it at some point.
Here is what I used
SEM 39033 Charcoal Trim
SEM 13023 Low Luster Clear Color
Krylon K01010A07 Premium Metallic Spray
Here's a couple pics of the can.
Duplicolor 261413 Metallic Carbon Mist:
I tried two varieties of matte top-coat and didn't find much difference. I tried Rust-Oleum Matte Clear (#285093) and Krylon Colormax Flat Clear (#53530).
Of those two varieties, I found the Krylon to be a tiny bit more flat than the Rust-Oleum, so I went with the Krylon.
Yesterday I pulled my tail light finisher parts and my grill and hubcaps out from storage to take some color comparison pictures inside with flash on and off and outside in filtered sun. I wanted to try in full sun but I lost my opportunity when the high clouds came in. Here are the results. The grill is original, not repainted.
Inside with flash off...
Inside with flash on...
A couple outside, filtered sun (no flash)...
Lastly here are couple of cut and paste comparison with snippets from @kats that I "borrowed".
Edited by CanTechZ
@CanTechZ Unfortunately lighting can play such a huge role in how things like this look, especially in pictures. It's really hard to do comparisons with one variety and another.
If you can get your hands on a can of that Rust-Oleum 261413 Metallic Carbon Mist, give it a try on a test piece and see what you think. I had my taillight panels completely done, clear matte coat and all, with the Ford Dark Shadow and I was never completely satisfied. That Ford color is really good, but I think the 261413 is better.
Give it a shot if you can find it. I bought some very thin aluminum sheet and I use that as my test coupons. I used to do it with cardboard, but the textured surface of the cardboard did not give accurate results.
Edited by Captain Obvious
If you can get your hands on a can of that Duplicolor 261413 Metallic Carbon Mist, give it a try on a test piece and see what you think. I had my taillight panels completely done, clear matte coat and all, with the Ford Dark Shadow and I was never completely satisfied. That Ford color is really good, but I think the 261413 is better.
Thanks CO, I agree on your comment about lighting, it does make any comparison somewhat subjective. I will try to find some Metallic Carbon Mist, I think you meant to say it's a Rust-Oleum Product. Adding confusion, I found that in Canada it has a different part number, 264656, not 261413. They carry 264656 up here at Home Depot, but the stores near me are currently out of stock. Here's the links to Carbon Mist in the US and Canada.
https://www.rustoleum.com/product-catalog/consumer-brands/universal/universal-mist-metallic-spray-paint?ls=261413&lc=Metallic Carbon Mist
https://www.rustoleum.ca/product-catalog/consumer-brands/universal/metallic?ls=264656&lc=Carbon Mist
When I can get my hands on some and have a chance, I will do a test spray on the spare tail light finisher panel I first tested DC Dark Shadow Gray on and report back. Who knows maybe I will like it better and respray mine when I complete my resto.
Cheers, Mike
Edited by CanTechZ
  • Who's Online   2 Members, 0 Anonymous, 964 Guests (See full list)
