Well, the only thing that will be new here is dealing with the cam chain. Don't let go slack and fall down into the housing. If you don't already have a repair manual, get one. It will show you what you need to retain the chain while the head is removed. If the chain does fall down inside the housing, you have two problems....#1 you have to fish it out....#2 (MOST IMPORTANTLY) you will loose the timing relationship between the chain and crank sproket and you will have to remove the front housing and reposition the chain. Definitely read the repair manual, as it will also show you the wedge you need to maintain the position of the chain during disassembly and re-assembly.
