Pertronix Ignitor I won't rev - Alternative solution
SteveJ
1 hour ago, Diseazd said:
Great job Steve…..I changed points once and the car wouldn’t fire. Took me 20 minutes to figure out that there is a little piece of protective paper between the new point contacts……🤪
That's the thing. Any of us (and that includes me) can make those little mistakes, often times not even realizing it happened. I've done things like try to start the car without the wire on the coil or with the rotor sitting on the fender. When it's not as obvious, it's easy to get frustrated and start loading the parts cannon to replace all of those bad parts that aren't really bad.
In my friend's case, I could hear his frustration as he repeatedly swapped in parts with no success. That's why I went over to his place with the plan of getting a baseline and examining each part and correct each issue I encountered. This time, it was an easy solution.
  • Like 3
  • Who's Online   2 Members, 0 Anonymous, 663 Guests (See full list)
