Looks okay in that picture.
As said before, check all of them.  If you want to get a better idea, mark all of the wear pads with some layout fluid or a magic marker then rotate the engine a few times.  The cam will rub away the marking and show you what's happening.  Some of the wear might be from before the new camshaft was installed.  Good luck.
