February 25, 20232 yr Author comment_650681 1 hour ago, Mark Maras said: Do you know if he held the throttle wide open during the tests? I just turned the key without stepping on the gas pedal. It was done just removing one plug at the time Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=9#findComment-650681 Share on other sites More sharing options...
February 26, 20232 yr comment_650683 Surprised the mechanic let you/showed you this method. At least this explains the low compression numbers. If you can, do the test again with all spark plugs removed and throttle wide open. You'll get better results 🙂 Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=9#findComment-650683 Share on other sites More sharing options...
February 26, 20232 yr Author comment_650689 1 hour ago, Barefootdan said: Surprised the mechanic let you/showed you this method. At least this explains the low compression numbers. If you can, do the test again with all spark plugs removed and throttle wide open. You'll get better results 🙂 Distributor cap pic Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=9#findComment-650689 Share on other sites More sharing options...
February 26, 20232 yr comment_650700 14 hours ago, jalexquijano said: It was a digital compression tester Hah! I think it was a BROKEN compression tester.. You normally do this in Psi? we do it in bar or ato or KPa. you need to have around 150 Psi on a healthy engine.. so look for a good compression tester.. i bought one many years ago for about 30 bucks.. a GOOD INVESTMENT!!! Take out all plugs, start for about 10 sec. (try to lay the meter so that you can see it come up..) and test them yourself. (And remember, can't do it myself.. does not excist in your vocab! ) Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=9#findComment-650700 Share on other sites More sharing options...
February 26, 20232 yr comment_650701 Also i bet you had to pay the guy more than 30 bucks.. When you would have bought the meter yourself you had one now to do many many other engines as well.. I also think, and don't get me wrong, someone who wants to drive a classic car needs to have some skill's to work at these old cars.. otherwise it's gonna cost you a LOT in a short time. (Also often garages don't understand these cars anymore. all they want is put an analizer to it.. well good luck there! 🤣 ) Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=9#findComment-650701 Share on other sites More sharing options...
February 26, 20232 yr comment_650712 You know you are in trouble when the shop asks "is it OBD1 or 2?"🤣 Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=9#findComment-650712 Share on other sites More sharing options...
February 26, 20232 yr Author comment_650721 Shop charged me 60 bucks jajaaj Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=9#findComment-650721 Share on other sites More sharing options...
February 26, 20232 yr Popular Post comment_650733 That's unfortunate considering the numbers are not accurate and basically useless. I agree with buying your own gauge and doing it yourself. I am sure you have the skills to accomplish this with a little instruction from us. Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=9#findComment-650733 Share on other sites More sharing options...
March 1, 20232 yr Author comment_650919 On 2/26/2023 at 3:54 PM, Patcon said: That's unfortunate considering the numbers are not accurate and basically useless. I agree with buying your own gauge and doing it yourself. I am sure you have the skills to accomplish this with a little instruction from us. Is this the correct way to carry out the compression test? Im done with these mechanics here in Panama: Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=9#findComment-650919 Share on other sites More sharing options...
March 1, 20232 yr Author comment_650920 Im actuall running BP5ES in all 6 cylinders, should i consider getting a BP4ES for cyl 4? Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=9#findComment-650920 Share on other sites More sharing options...
March 1, 20232 yr comment_650928 2 hours ago, jalexquijano said: Is this the correct way to carry out the compression test? Im done with these mechanics here in Panama: The only thing I can add is I remove the plugs and turn the engine over until I see oil pressure, then test. When I didn't start with oil pressure #1 would read low the first time and higher on the second test. Good luck. Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=9#findComment-650928 Share on other sites More sharing options...
March 1, 20232 yr comment_650930 I think you’re on the right track doing these things your self. As my post#79 I recommend a leak down test after you get accurate compression readings. We are here to help. Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=9#findComment-650930 Share on other sites More sharing options...
