bluez Posted March 3, 2023 Share #121 Posted March 3, 2023 Note, battery should be fully charged to allow full cranking. Also, remember motor should be hot, so valve train is seated. Then remove the plugs. 1 Link to comment Share on other sites More sharing options...
jalexquijano Posted March 3, 2023 Author Share #122 Posted March 3, 2023 10 hours ago, bluez said: Note, battery should be fully charged to allow full cranking. Also, remember motor should be hot, so valve train is seated. Then remove the plugs. Ok. So i must take the car for a spin and then perform the tes as @Mark Maras described. I also posted a youtube video for reference Link to comment Share on other sites More sharing options...
Mark Maras Posted March 3, 2023 Share #123 Posted March 3, 2023 I don't like to compression test a hot engine because I don't like to remove spark plugs from a hot engine. However if the plugs come out easily it's better to test the engine when it's warm. 1 Link to comment Share on other sites More sharing options...
jalexquijano Posted March 3, 2023 Author Share #124 Posted March 3, 2023 Do you concur with the Video i posted? Link to comment Share on other sites More sharing options...
bluez Posted March 3, 2023 Share #125 Posted March 3, 2023 Video is fine, except for failing to mention engine should be at normal temperature. A hot engine will give you the most accurate compression readings. When testing my engine cold, I found low readings around 130, hot engine were around 170. I like these numbers better.. 1 Link to comment Share on other sites More sharing options...
Patcon Posted March 4, 2023 Share #126 Posted March 4, 2023 I agree with Mark, I don't like to remove steel spark plugs from an aluminum head when hot. Too much chance for thread damage. I also agree that a remote starter makes this an easy job. You don't even need to turn the key on and it can all be done without getting into or reaching into the car. 1 Link to comment Share on other sites More sharing options...
siteunseen Posted March 4, 2023 Share #127 Posted March 4, 2023 I watched the video and it shows the screwdriver trick to hold the carbs open. That'd be the easiest thing to do. Link to comment Share on other sites More sharing options...
bluez Posted March 4, 2023 Share #128 Posted March 4, 2023 If plugs were torqued correctly (11-15 ft lbs) there should be no issue with stripping threads, unless they’ve been in for several years. 1 Link to comment Share on other sites More sharing options...
jalexquijano Posted March 5, 2023 Author Share #129 Posted March 5, 2023 (edited) Plugs pulled out before test. Now i will place the dry test results for your kind reference. I will only perform wet test on plug 4 Edited March 5, 2023 by jalexquijano Link to comment Share on other sites More sharing options...
jalexquijano Posted March 5, 2023 Author Share #130 Posted March 5, 2023 On 3/2/2023 at 7:54 PM, Mark Maras said: Remove the coil wire, remove the spark plug wires and spark plugs, get comfortable in the seat and turn the engine over (wide open throttle) with the starter until you see oil pressure on the gauge. It shouldn't take long. Then proceed with the test. Dry test results with choke fully open and gas pedal floored: Cyl 1: 148 psi Cyl 2: 150 psi Cyl 3: 146 psi Cyl 4: 150 psi Cyl 5: 150 psi Cyl 6 : 149 psi Wet - Cyl 4: 160 psi 2 Link to comment Share on other sites More sharing options...
Yarb Posted March 5, 2023 Share #131 Posted March 5, 2023 (edited) I think those are decent numbers…Would like to get an opinion from other folks on running the leak down test just.. to confirm the engine status. Edited March 5, 2023 by Yarb 1 1 Link to comment Share on other sites More sharing options...
jalexquijano Posted March 5, 2023 Author Share #132 Posted March 5, 2023 Im not opening that engine until i get a precise advice from the Group Link to comment Share on other sites More sharing options...
