April 3, 2024Apr 3 comment_663599 Those contraptions are called non-foulers that were sold many years ago for worn out motors burning oil. Definitely not a permanent fix by any means. They came about over 50 years ago when I worked in my family’s auto part store. Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=33#findComment-663599 Share on other sites More sharing options...
April 4, 2024Apr 4 comment_663600 I have this neat tool I would love to test number 4 with. Spark KV, Burn KV, Burn time in ms. Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=33#findComment-663600 Share on other sites More sharing options...
August 3, 2024Aug 3 Author comment_667917 Well guys this problem got worst. Now all spark plugs are black. Heavy hesitation when accelerating and lots of misfiring. Cant stand this problem any longer. Posting a pic of all 6 spark plugs 6 5 3 4 3 2 1 Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=33#findComment-667917 Share on other sites More sharing options...
August 4, 2024Aug 4 comment_667921 You still running the pertronix??? Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=33#findComment-667921 Share on other sites More sharing options...
August 4, 2024Aug 4 comment_667922 Is this just sudden in one day or a couple days? Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=33#findComment-667922 Share on other sites More sharing options...
August 4, 2024Aug 4 Author comment_667924 23 minutes ago, Patcon said: You still running the pertronix??? Yes Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=33#findComment-667924 Share on other sites More sharing options...
August 4, 2024Aug 4 comment_667926 If it were mine I would swap out the entire ignition system. Coil and distributor with no pertronix Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=33#findComment-667926 Share on other sites More sharing options...
August 4, 2024Aug 4 Author comment_667929 Should i check the choke cables? Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=33#findComment-667929 Share on other sites More sharing options...
August 4, 2024Aug 4 comment_667930 you can check the cables, but make 100% sure the choke lever on the bottom of the carb is not stuck on. Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=33#findComment-667930 Share on other sites More sharing options...
August 4, 2024Aug 4 comment_667950 It does sound like the chokes may be stuck open. This can happen if the screw for the linkage to the choke tube is too tight. Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=33#findComment-667950 Share on other sites More sharing options...
August 5, 2024Aug 5 comment_667977 Do what Charles @Patcon says... Replace the ignition system once you've verified the choke isn't stuck. Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=33#findComment-667977 Share on other sites More sharing options...
August 6, 2024Aug 6 Author comment_668024 Just removed the air filter assembly. Should i loosen the screws and remove choke cables completely? Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=33#findComment-668024 Share on other sites More sharing options...
