November 20, 20222 yr comment_647385 Let's start with establishing a baseline of tune: Edited November 20, 20222 yr by DatsunZGuy Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=2#findComment-647385 Share on other sites More sharing options...
November 20, 20222 yr Author comment_647386 2 turns does not give enough power to drive the car. Mine are set to 3.5 and 4 turns rear. Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=2#findComment-647386 Share on other sites More sharing options...
November 21, 20222 yr comment_647387 your float setting is off . Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=2#findComment-647387 Share on other sites More sharing options...
November 21, 20222 yr comment_647388 1 hour ago, jalexquijano said: 2 turns does not give enough power to drive the car. Mine are set to 3.5 and 4 turns rear. Refresh my memory please. What happens when you raise the nozzles? Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=2#findComment-647388 Share on other sites More sharing options...
November 21, 20222 yr comment_647392 As I recall it doesn't foul all the plugs. Just the one Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=2#findComment-647392 Share on other sites More sharing options...
November 21, 20222 yr comment_647399 19 hours ago, jalexquijano said: How come after 8 years im still pulling plugs after they get fouled from 30 mins at idle either on traffic or at the shop? Been struggling with this and nothing. Charles has a good memory. It was, as I recall, just #4 that was fouling. Are they all fouling now after idling? Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=2#findComment-647399 Share on other sites More sharing options...
November 21, 20222 yr Author comment_647402 Let me explain this better: I adjusted the floats during the pandemic in 2020 when i had some spare time. I did this using a float sync device built and sold by one of the members here. If i close the fuel adjustment to 2.5 turns clockwise car has no power when accelerating. it even pops at the exhaust when releasing the gas pedal. Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=2#findComment-647402 Share on other sites More sharing options...
November 21, 20222 yr comment_647408 Is your clockwise adjustment your view from the top of the carb or is it looking at the adjustment screw from the bottom of the carb? This makes a huge difference. When we describe turning the mixture screw clockwise, we're imagining looking at it from the bottom of the carb and we're leaning the mixture out. If you're imagining looking at the screw from the top and turning it clockwise, you're richening it. You could pull a dome and watch the nozzle as you adjust the height and tell us if the nozzle rises or drops when you turn it clockwise. Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=2#findComment-647408 Share on other sites More sharing options...
November 21, 20222 yr Author comment_647410 you close the jet all the way up and then you turn 2.5 turns from the base line. Lean is when the jet is flush with the bridge of the carb. The nozzle drops when turning it. Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=2#findComment-647410 Share on other sites More sharing options...
November 22, 20222 yr comment_647434 7 hours ago, Mark Maras said: Is your clockwise adjustment your view from the top of the carb or is it looking at the adjustment screw from the bottom of the carb? This makes a huge difference. When we describe turning the mixture screw clockwise, we're imagining looking at it from the bottom of the carb and we're leaning the mixture out. If you're imagining looking at the screw from the top and turning it clockwise, you're richening it. You could pull a dome and watch the nozzle as you adjust the height and tell us if the nozzle rises or drops when you turn it clockwise. I just remember it as: Right = Rich Left = Lean Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=2#findComment-647434 Share on other sites More sharing options...
November 22, 20222 yr Author comment_647437 4 hours ago, DatsunZGuy said: I just remember it as: Right = Rich Left = Lean Thats correct. So how do i tackle this? Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=2#findComment-647437 Share on other sites More sharing options...
November 22, 20222 yr comment_647440 Do you know which needles ZTherapy supplied with the SUs? Link to comment https://www.classiczcars.com/forums/topic/67984-still-struggling-with-car-at-idle-after-8-years/?&page=2#findComment-647440 Share on other sites More sharing options...
