26th-Z Posted June 26, 2003 Share #1 Posted June 26, 2003 Will these towers fit on a E31 head? Can anyone give me a little advice on the technical info about these? Is this a good deal? And where can I find new ones?http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2420029459&category=33614 Link to comment Share on other sites More sharing options...
26th-Z Posted June 26, 2003 Author Share #2 Posted June 26, 2003 After a little research, I find that these cam towers will fit and I can't find new ones. I'm told the cam towers fit the head and that new ones must be line bored for proper alignment of the cam.I'm concerned about proper clearance between the cam and bearing surface.Any advice? Link to comment Share on other sites More sharing options...
Bambikiller240 Posted June 26, 2003 Share #3 Posted June 26, 2003 Originally posted by 26th-Z I'm told the cam towers fit the head and that new ones must be line bored for proper alignment of the cam. I'm concerned about proper clearance between the cam and bearing surface. Any advice? Well, the auction indicated the diameter of the holes for the cam (bearing surface) was within spec (but just barely AIR). Measure the cam that you have and see what diameters you have to work with. Check with a machine shop and see if they think there would be enough "meat" to line-bore the towers to fit the cam that you have to work with. Who knows, you MAY not even have to line-bore. Won't know until you take some measurements. Link to comment Share on other sites More sharing options...
26th-Z Posted June 26, 2003 Author Share #4 Posted June 26, 2003 Thanks, Carl. Best advice I've had all day. Link to comment Share on other sites More sharing options...
