October 1, 20231 yr comment_657680 Third day in a row taking the car out. Only 4 Zs showed up, including mine. That could be from ZNationals happening yesterday. Then there was this unique vehicle. I'm not used to taking car photos in portrait mode. Link to comment https://www.classiczcars.com/forums/topic/68064-2023-what-did-you-do-towith-your-z-today/?&page=8#findComment-657680 Share on other sites More sharing options...
October 1, 20231 yr comment_657682 On 10/1/2023 at 1:12 AM, Captain Obvious said: That's a beautiful EM-50. @SteveJ It's like going into Wisconsin. @Captain Obvious Well I got the $#!+ kicked out of me in Wisconsin once. Forget it! Edited October 1, 20231 yr by SteveJ Link to comment https://www.classiczcars.com/forums/topic/68064-2023-what-did-you-do-towith-your-z-today/?&page=8#findComment-657682 Share on other sites More sharing options...
October 2, 20231 yr Popular Post comment_657706 My Z is off the jackstands after I installed a new MSA exhaust and replaced the RMS, trans output seal and the speedo cable O ring. For anybody struggling to fit the MSA exhaust, after I cut 1" out of the Z bend pipe, and played with the rest for a while, I got it to fit very well. The front OE hanger that hangs the exhaust from the trans needs to be modified to fit the larger pipe and larger U bolt. 10 minutes with a die grinder and it fit great. I modified the bracket so that the top of the pipe was in the same spot so it didn't move up closer to the crossmember. The short straight pipe they give you goes behind the long pipe. If you try to put it behind the header, the angles are all wrong. Finally, the rear hanger is way too short for a 280Z. I had to add another strap. This week, I will put collector car insurance on it, change the title over from AZ to MI, and get collector car plates. In AZ, they are made of copper. I can actually start driving it again! Link to comment https://www.classiczcars.com/forums/topic/68064-2023-what-did-you-do-towith-your-z-today/?&page=8#findComment-657706 Share on other sites More sharing options...
October 3, 20231 yr comment_657765 On 10/1/2023 at 7:12 PM, SteveJ said: Third day in a row taking the car out. Only 4 Zs showed up, including mine. That could be from ZNationals happening yesterday. Then there was this unique vehicle. I'm not used to taking car photos in portrait mode. Spot the long shadows!! Winter is in the post! Link to comment https://www.classiczcars.com/forums/topic/68064-2023-what-did-you-do-towith-your-z-today/?&page=8#findComment-657765 Share on other sites More sharing options...
October 3, 20231 yr comment_657766 Duplicated post by crapatalk! Link to comment https://www.classiczcars.com/forums/topic/68064-2023-what-did-you-do-towith-your-z-today/?&page=8#findComment-657766 Share on other sites More sharing options...
October 5, 20231 yr comment_657814 I got the Z's title changed over to AZ and plated it today, so I gave it a maiden voyage of sorts. Before I went, I pulled the fuel sender to see if the tank was clean or a disaster and get a good sense of how the 13 year old fuel smelled. The fuel has just a whiff of old smell, but it's surprisingly mild and still smell like gasoline and not varnish. The sender came out spotless and the tank is clean as well. Sta-Bil is amazing stuff! The fuel gauge reads about 1/4 tank and there is about 4" of fuel in the tank. I've only put 61 miles on it since I filled it 13 years ago, so I'm not sure if some evaporated. The car ran amazingly well tonight for very old gas. The oil pressure is perfect, temp is right where it should be, the alternator is charging, the fuel gauge seems to work and the clock still keeps time. Just to be safe, I did take a fire extinguisher which I will keep in the car for a while. It has no leaks now and the exhaust sounds pretty decent. It isn't too loud, but has a nice tone. So far, I haven't heard any drone, but I didn't get over about 50 mph on the surface streets. I did a 20 minute drive and tucked it away for the night. I'm torn between filling the tank now, or running the old fuel down via short drives before I put fresh gas in it. I'm not as worried about the old fuel based on how well it runs. It idles smoothly at 700 rpm and accelerates cleanly. It doesn't have the higher RPM power it should, but I'll accept that. Link to comment https://www.classiczcars.com/forums/topic/68064-2023-what-did-you-do-towith-your-z-today/?&page=8#findComment-657814 Share on other sites More sharing options...
October 5, 20231 yr comment_657822 I'm torn on whether to drive the fuel lower or dilute it. I think I would add some premium to what you have. Maybe 1:1 or so. That way maybe you could make some longer trips. How are the hydraulics? Link to comment https://www.classiczcars.com/forums/topic/68064-2023-what-did-you-do-towith-your-z-today/?&page=8#findComment-657822 Share on other sites More sharing options...
October 5, 20231 yr comment_657824 On 10/5/2023 at 9:48 AM, Patcon said: I'm torn on whether to drive the fuel lower or dilute it. I think I would add some premium to what you have. Maybe 1:1 or so. That way maybe you could make some longer trips. How are the hydraulics?I’m in the drain and fill fresh, or dilute it as much as you can, camp. Old fuel isn’t going to kill it but won’t be great to run it down. You have no idea how much crud could be settled at the bottom of that tank / around the pick-up and you maybe asking for trouble running it down!If it was mine, I would pull the tank, flush it through and even drop an endoscope (or point an iPhone camera) in there. You can also check hose conditions etc at the same time.That’s my 2 cents at least ;) Link to comment https://www.classiczcars.com/forums/topic/68064-2023-what-did-you-do-towith-your-z-today/?&page=8#findComment-657824 Share on other sites More sharing options...
October 5, 20231 yr comment_657825 Would it work to use a non Apple phone too Ali? @AK260😜 Link to comment https://www.classiczcars.com/forums/topic/68064-2023-what-did-you-do-towith-your-z-today/?&page=8#findComment-657825 Share on other sites More sharing options...
October 5, 20231 yr comment_657826 On 10/5/2023 at 9:48 AM, Patcon said: I'm torn on whether to drive the fuel lower or dilute it. I think I would add some premium to what you have. Maybe 1:1 or so. That way maybe you could make some longer trips. How are the hydraulics? The hydraulics are good. Before I woke it up in 2021, I flushed the brake fluid, but I forgot to do the clutch. After a few miles of driving in AZ, the clutch slave puked. I replaced the clutch slave and flushed a bunch of fluid through the system. I did buy a new clutch master just in case, but it will sit on the shelf for now. The brakes feel great, so for now, I will just monitor. I'll probably flush the brake fluid again when I get a chance. I will probably go ahead and fill the tank with fresh gas. Link to comment https://www.classiczcars.com/forums/topic/68064-2023-what-did-you-do-towith-your-z-today/?&page=8#findComment-657826 Share on other sites More sharing options...
October 5, 20231 yr comment_657827 On 10/5/2023 at 10:42 AM, AK260 said: I’m in the drain and fill fresh, or dilute it as much as you can, camp. Old fuel isn’t going to kill it but won’t be great to run it down. You have no idea how much crud could be settled at the bottom of that tank / around the pick-up and you maybe asking for trouble running it down! If it was mine, I would pull the tank, flush it through and even drop an endoscope (or point an iPhone camera) in there. You can also check hose conditions etc at the same time. That’s my 2 cents at least 😉 If I had any lawn mowers, or other small engines, I would drain the tank, but I have nothing to burn it in these days. When I moved to AZ, I sold off all of my gas powered equipment. As for debris in the tank, I have a '78, so I was able to pull the sender and see inside the tank. It looks perfectly clean, so I don't think I have anything to worry about there. The sender looked like new with no signs of varnish. I did clean and seal the tank about 15 years ago and it looks just like it did after I finished. I will replace the fuel filter once all the old fuel has been run through. The underbody hoses are all original, but I'm guessing most people on here are in the same boat. I did replace all of the underhood hoses and injector hoses about 20 years ago when I replaced the injectors. Link to comment https://www.classiczcars.com/forums/topic/68064-2023-what-did-you-do-towith-your-z-today/?&page=8#findComment-657827 Share on other sites More sharing options...
October 5, 20231 yr comment_657829 On 10/5/2023 at 12:29 PM, jonbill said: Would it work to use a non Apple phone too Ali? [mention=32052]AK260[/mention][emoji12]Ha! Not sure!? :sFunny thing is, after emptying mine and leaving it for a couple of days I literally dropped a head torch in there for better light and the lense started to react with the fumes left in there! Link to comment https://www.classiczcars.com/forums/topic/68064-2023-what-did-you-do-towith-your-z-today/?&page=8#findComment-657829 Share on other sites More sharing options...
