January 11, 20232 yr comment_649216 On 1/11/2023 at 3:07 PM, kats said: Hi, just a reminder of the difference between the two of interior trim panel. The Blue one is an early type which has a small box for the plastic tank. The black one is a later type which has a larger box for the metal tank. If you put a metal tank into an early car, the trim panel would not fit properly. Kats These right hand rear quarter trim panel are used for all the S30 series no matter how the car equipped with the tank or not. March 1973, when Japanese automobile emissions regulations began to be serious, Fairlady Z series got the vapor tank associated with a gas tank(E4600) and HMB carburetors (for L24) but no air pump. Kats Edited January 11, 20232 yr by kats Link to comment https://www.classiczcars.com/forums/topic/68071-hoarding-z-parts/?&page=6#findComment-649216 Share on other sites More sharing options...
January 11, 20232 yr comment_649217 A question for you ladies and gents - after my restorations, I kept the "windlace" - not sure if thats the correct wording- the molding that went around the original door seals. I believe the new replacement seals include this part. Are these moldings still useful, worth anything or should I get rid of them? If you need better/more pics, let me know. There are 8 pieces - 4 per side. thanks Link to comment https://www.classiczcars.com/forums/topic/68071-hoarding-z-parts/?&page=6#findComment-649217 Share on other sites More sharing options...
January 11, 20232 yr comment_649218 Are you referring to the flocked channel seal (Bailey strip)? Keith Link to comment https://www.classiczcars.com/forums/topic/68071-hoarding-z-parts/?&page=6#findComment-649218 Share on other sites More sharing options...
January 11, 20232 yr comment_649221 On 1/11/2023 at 8:20 PM, Hank240 said: A question for you ladies and gents - after my restorations, I kept the "windlace" - not sure if thats the correct wording- the molding that went around the original door seals. I believe the new replacement seals include this part. Are these moldings still useful, worth anything or should I get rid of them? If you need better/more pics, let me know. There are 8 pieces - 4 per side. thanks You are correct that in some of the replacement weather stripping this is included with the door weather strip as a one piece design. What you have would be useful if someone wanted to stay with original two part design. This material is generally referred to as welting. Here is a discussion with some more info. Edited January 11, 20232 yr by CanTechZ Link to comment https://www.classiczcars.com/forums/topic/68071-hoarding-z-parts/?&page=6#findComment-649221 Share on other sites More sharing options...
January 12, 20232 yr comment_649225 On 1/11/2023 at 3:07 PM, kats said: Hi, just a reminder of the difference between the two of interior trim panel. I have always looked at the speaker holes. There is a noticeable flat spot between the bump and holes on the early and no gap on the later. Link to comment https://www.classiczcars.com/forums/topic/68071-hoarding-z-parts/?&page=6#findComment-649225 Share on other sites More sharing options...
January 12, 20232 yr comment_649226 I could swear I read that someone on these boards was looking for the welting? Link to comment https://www.classiczcars.com/forums/topic/68071-hoarding-z-parts/?&page=6#findComment-649226 Share on other sites More sharing options...
January 12, 20232 yr comment_649238 Thanks @CanTechZ. Link to comment https://www.classiczcars.com/forums/topic/68071-hoarding-z-parts/?&page=6#findComment-649238 Share on other sites More sharing options...
January 12, 20232 yr comment_649239 On 1/12/2023 at 2:09 AM, w3wilkes said: I could swear I read that someone on these boards was looking for the welting? It might be @Patcon, but I believe he is looking for the roof head liner welting. I just checked and the head liner welting is about 3mm (1/8") shorter than the door seal welting. Door seal welting is 14mm channel height and the head liner welting is 11mm channel height. Edited January 12, 20232 yr by CanTechZ Link to comment https://www.classiczcars.com/forums/topic/68071-hoarding-z-parts/?&page=6#findComment-649239 Share on other sites More sharing options...
January 12, 20232 yr comment_649240 On 1/12/2023 at 3:23 PM, Hank240 said: Thanks @CanTechZ. You're welcome Link to comment https://www.classiczcars.com/forums/topic/68071-hoarding-z-parts/?&page=6#findComment-649240 Share on other sites More sharing options...
January 13, 20232 yr comment_649245 Thanks @CanTechZ. Actually I need to find both... Link to comment https://www.classiczcars.com/forums/topic/68071-hoarding-z-parts/?&page=6#findComment-649245 Share on other sites More sharing options...
January 16, 20232 yr Author comment_649355 On 1/11/2023 at 8:52 AM, HS30-H said: The '46 6 23' date stamp translates to 23rd June 1971. '46' = 46th year of Showa = 1971 (First year of Emperor Showa's reign was 1925). '6' = Month of June. '23' = 23rd day of the month. Thanks for the information, Alan. By the month of manufacture stamped on the door tag, and the VIN number compared with others on the Zhome registry, I figured my car was completed in the back half of the month of June, 1971. By the date stamp on my tank, I wonder if I can conclude that it was completed on that day. Seems likely. Since that day in 1971, 51 years, 6 months and 8 days have passed. Hopefully, in another 6 months, I'll have the restoration on this one completed. Wish I could find a jack and wheel chocks with the correct date stamps. And for that matter, an original spare tire with a date stamp that is before, but around that, the 26th week of 1971: Edited January 16, 20232 yr by inline6 Link to comment https://www.classiczcars.com/forums/topic/68071-hoarding-z-parts/?&page=6#findComment-649355 Share on other sites More sharing options...
January 16, 20232 yr Author comment_649356 A couple of discontinued, NOS parts in my hoard for the car I am restoring: Edited January 16, 20232 yr by inline6 Link to comment https://www.classiczcars.com/forums/topic/68071-hoarding-z-parts/?&page=6#findComment-649356 Share on other sites More sharing options...
